electrical problems
Old Jul 6, 2003 | 02:48 AM
vtNaMeSe's Avatar
Default electrical problems
one of my fuses blew out . . the one that is connected to my parking lights , my gauge light, and my tail-light . . i replace it with a new 15 amp fuse and it keeps on fry'n that piece of **** . . . dunno what to do . . need help
its a 94 accord ex coupe
Old Jul 6, 2003 | 05:13 AM
RUBZERK's Avatar
Default Re: electrical problems (vtNaMeSe)
did you change your lights with after markets or add aaltezzas or anything?
Old Jul 6, 2003 | 05:20 AM
YeuEmMaiMai's Avatar
find the short that is causing you to blow fuses.....
Old Jul 6, 2003 | 12:32 PM
vtNaMeSe's Avatar
Default Re: (YeuEmMaiMai)
how am i suppose to find the short . . . i do have after market tail lights but i install it while back ago wasn't recently . . all of a sudden one day the fuse just blew n i got a short circuit . .
Old Jul 6, 2003 | 12:43 PM
dude if you do not know how to use a volt/ohm meter, it is best that you do NOT work on your car.......you can really screw yourself over if you do not know what you are doing and fron the sounds of it, you don't
Modified by YeuEmMaiMai at 6:27 PM 7/6/2003
Old Jul 6, 2003 | 03:23 PM
vtNaMeSe's Avatar
i was just asking for help man . . . yea i don't know much but i would like some tips thats all . .
Old Jul 6, 2003 | 03:27 PM
Default Re: (vtNaMeSe)
take the VoltMeter set to the OHMS setting and see if there is a short between the +12V and ground if there is you need to find it and repair it
Old Jul 6, 2003 | 03:32 PM
93LoProLX's Avatar
the wiring for one of the lights using that fuse has a problem such as worn away plastic. so if the wire is exposed, it could be shorting out any time it hits the frame of the car. you also could have enough condensation in one of your light housings to cause a short, although if it doesn't look too apparent, then this likely isn't your problem. if you spent any time splicing wires (you said you replaced the taillights) check the connections you made, and make sure there's no exposed wires. the most basic thing you can do right now is to look for physical signs of wear and tear on the wiring, although it won't be the easiest or most complete way since you won't be able to inspect everything.
moarlow95ex
Jan 9, 2014 09:14 PM
jdmEF8racer
Sep 2, 2011 09:48 PM
hondaheadache
Aug 5, 2006 07:57 PM
DrakeMK3
Sep 18, 2005 07:22 AM
MrSmith
Jun 13, 2002 11:01 AM
