CEL codes
Old Feb 23, 2004 | 06:53 PM
fe519's Avatar
Default CEL codes
maybe this sounds idiodic... I have a OBDII. Sometimes you can get stored codes by jumping the 2 wire together. But would a OBDII scanner do the same? how about even if the CEL is not on but there is a code stored?
Old Feb 23, 2004 | 06:59 PM
Nick H's Avatar
New User
Default Re: CEL codes (fe519)
the cel would be on if the code was stored...the way to get rid of stored codes is to either unplug the ecu for more than 15 seconds or remove the ecu fuse under the hood for more than 15 seconds...
Old Feb 23, 2004 | 07:08 PM
fe519's Avatar
Default Re: CEL codes (Nick H)
but would a OBDII scanner do everything that jumping the wires would do?
Old Feb 23, 2004 | 07:10 PM
Nick H's Avatar
New User
it actually does more...apparently it will check all the sensors and calculate different parameters for you...it can also clear codes and check the "stored" codes as well...it will also limp or unlimp your car as well...it's just a neat tool to have, but unfortunately it's expensive...
Old Feb 23, 2004 | 07:13 PM
fe519's Avatar
thanks for your help. youve been a great help
Old Feb 23, 2004 | 07:17 PM
Nick H's Avatar
New User
yeah, but one more thing...if you do decide to get one of the scanners, don't cheap out...you get what you pay for...i believe some of them even connect to a laptop, which would be my choice...anyways, goodluck
Old Feb 24, 2004 | 07:34 AM
JimBlake's Avatar
Nick, have you got one? What kind? I'm kinda thinking about getting one, but I'm not sure what kind.
Old Feb 24, 2004 | 12:26 PM
Nick H's Avatar
New User
Default Re: CEL codes (JimBlake)
no, i don't have one...i am obd1
Old Feb 24, 2004 | 04:49 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H &raquo;</TD></TR><TR><TD CLASS="quote">the cel would be on if the code was stored...
Not always. Temporary codes wont turn on the light. Also with some problems, if the light was on and the ECU doesn't see the problem for a number of drive cycles, the light will go out. But the code will remain in memory.
Hetterley
Engine Management and Tuning
Apr 19, 2016 06:54 PM
radicaled434
Feb 23, 2013 06:45 PM
gtcaraudio
Jan 25, 2008 06:57 PM
benjamin
Oct 29, 2004 09:31 PM
B18EG6
Nov 8, 2002 07:22 AM
