how to replace a 93 2dr window
Old Feb 21, 2004 | 01:55 PM
blkgsr03's Avatar
Default how to replace a 93 2dr window
is there a site to show how to take apart a 93 accord 2dr ex door panel? im trying to replace a window from the passenger side. need a lil help. thanks
Old Feb 21, 2004 | 02:17 PM
The_Todd's Avatar
Farts in the shower
Default Re: how to replace a 93 2dr window (CiViC KiD)
I could probably tell ya by memory. It should be the same as 1990. *I don't remember which is easiest if the window is all the way up, half down or all the way*
1.) First thing there is a bolt in the arm rest part and there should be a cover just remove that and unscrew it.
2.) There should be another cover and bolt under the door handle unscrew that.
Now work the clips surrounding the inside door panel. There should be like 5-10 (I don't remember).
3.) After that the door panel should be able to come off and now set it aside and move the plastic aside and loosen the 2 bolts holding the window glass in the track. **I would recommend spraying the track with silicon lubricant while you have it opened**
4.) Replace glass and line up window guide with new glass and reverse steps to put it back together.
Again this was all from memory and from my 90 accord so it should be close if not right on. Hope it helps
Old Feb 21, 2004 | 02:19 PM
blkgsr03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CiViC KiD &raquo;</TD></TR><TR><TD CLASS="quote">is there a site to show how to take apart a 93 accord 2dr ex door panel? im trying to replace a window from the passenger side. need a lil help. thanks</TD></TR></TABLE>
i will try this out... thanks for tha help!
Andyxramirez
Mar 14, 2013 07:20 PM
aznomb
Honda Civic (2001 - 2005)
Jul 9, 2010 03:46 AM
BootcutSoldier
Oct 16, 2007 07:56 PM
DOHC_VTEC69
Feb 3, 2005 11:39 AM
Littleaccordman
Aug 29, 2004 10:40 PM
