Ecu codes-check engine light
Old Feb 21, 2004 | 02:39 PM
eric416's Avatar
Default Ecu codes-check engine light
can someone tell me how to check the codes on a 1996 accord ex and what the codes mean? i dont know where the jumper is.
Old Feb 21, 2004 | 05:54 PM
Chiovnidca's Avatar
Default Re: Ecu codes-check engine light (eric416)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eric416 &raquo;</TD></TR><TR><TD CLASS="quote">can someone tell me how to check the codes on a 1996 accord ex and what the codes mean? i dont know where the jumper is.</TD></TR></TABLE>
It'as the 2-pin connector under/behind the glove box.
Old Feb 21, 2004 | 06:00 PM
Nick H's Avatar
New User
Default Re: Ecu codes-check engine light (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
It'as the 2-pin connector under/behind the glove box. </TD></TR></TABLE>
and simply close the loop
Old Feb 22, 2004 | 10:36 AM
eric416's Avatar
Default Re: Ecu codes-check engine light (Nick H)
under the glove box i only see an orange plug and it has 3 pins not 2. also where can i find what the codes mean?
Old Feb 22, 2004 | 11:33 AM
Chiovnidca's Avatar
Look for a blue 2-pin connector right next to a blue 3-pinner.
Old Feb 23, 2004 | 04:14 PM
Auto Solutions's Avatar
Pull the ash tray and plug in an OBD II and it will spit out a code. I would bet it is a 141. (the most frequent code on those things)
Old Feb 23, 2004 | 05:32 PM
eric416's Avatar
Default Re: Ecu codes-check engine light (Auto Solutions)
one problem, i dont have an OBD II. so its the blue plug under the dash that i have to use the jumper on??
rotascircuit
Mar 24, 2008 05:22 PM
vtec25
Dec 27, 2006 07:36 AM
Quade
Nov 24, 2005 12:15 PM
Carson89X
Feb 10, 2005 08:17 AM
Monty
Oct 18, 2002 04:01 PM
