window problems
Old May 27, 2004 | 05:24 PM
jsmooney's Avatar
Default more electronic problems
okay, so now all the windows are broken, and the tach and speedo and all the gauges will not work. The radio works fine, but the clock works. I am just confused about this whole issue.
Thanks,
Mooney
Modified by jsmooney at 9:08 PM 6/1/2004
Old May 27, 2004 | 05:27 PM
.bagged's Avatar
Default Re: window problems (jsmooney)
check grounds
Old May 27, 2004 | 05:28 PM
jsmooney's Avatar
Default Re: window problems (bagged93accord)
grounds for the individual motors or is there a main relay/unit? there was a grounding problem with the ecu before....
Old May 27, 2004 | 05:29 PM
.bagged's Avatar
check all of them. just to be sure.
Old May 27, 2004 | 07:33 PM
briq4's Avatar
well if you have the window lock out turned on, only the drivers side window will open and the other three will not, before you got looking at fuses etc, make sure that the lock out switch isn't on.
Old May 28, 2004 | 10:13 PM
jsmooney's Avatar
Default Re: window problems (briq4)
coorect, all 4 windows dont work, fuses are good
Old Jun 1, 2004 | 06:53 PM
jsmooney's Avatar
BUMP
Old Jun 1, 2004 | 07:05 PM
opey045's Avatar
smoked08
Sep 13, 2010 07:04 PM
Blaze87
Honda Civic (2001 - 2005)
Oct 21, 2009 05:45 PM
ColMustard
Dec 3, 2007 10:13 AM
RP215.
Jan 29, 2007 06:12 PM
91integraLSVTEC
May 10, 2005 01:15 PM
