AC and Idle Problems
Old May 24, 2004 | 02:01 PM
abeaujuin's Avatar
Default AC and Idle Problems
I am still having problems with the Idleing when the AC is on. I have a 5 speed and everytime I get into neutral with the AC on, the idle drops close to 0 rpm and then corrects it self.
I clean the throttle with cleaner and added Fuel injection cleaner.
Could the timing be off? Fuel pump be bad?or something?
Old May 24, 2004 | 03:48 PM
The_Todd's Avatar
Farts in the shower
Default Re: AC and Idle Problems (abeaujuin)
You should be able to adjust (somewhat) your idle...if you look at your IM from the passenger side (looking into the intake tube) there is a small screw, adjust that.
Old May 24, 2004 | 04:59 PM
jwogen1's Avatar
Default Re: AC and Idle Problems (VRDrvr)
with the ac on, sometimes the idle will drop a little
Old May 25, 2004 | 07:51 AM
abeaujuin's Avatar
Default Re: AC and Idle Problems (jwogen1)
When the AC comes the idle goes up and then comes back down, but when it comes back down, it goes too low as if the car is about to shut off, which isn't normal in a Honda Accord.
I think after I adjust the timing from the Distributor, that’s when this started. I am not sure. Though.
Would too much Freon in the AC compressor cause this?
How about Fuel Filter?
Old May 25, 2004 | 07:55 AM
The_Todd's Avatar
Farts in the shower
No those 2 problems would cause more than your idle dropping.
IMO check your dizzy and your idle control (that screw I was talking about) it helped me out
Old May 25, 2004 | 08:16 AM
abeaujuin's Avatar
What is a Dizzy? I will adjust that screw and see what happens.
Old May 25, 2004 | 09:28 AM
boonacka's Avatar
i am having the same problem. i adjusted the idle screw according to the procedures in the Haynes manual and my idle still drops near zero then comes back up. i had to retard my distro a couple degrees, would that cause much of the problem? or should i just try and clean out my IAC valve?
Old May 25, 2004 | 11:25 AM
abeaujuin's Avatar
Default Re: AC and Idle Problems (boonacka)
Yeah it seams like when the fan comes on it's worst, like the battery doesn't hav e enough power when the fan comes on. What's an IAC valve?
Old May 26, 2004 | 04:47 AM
boonacka's Avatar
idle air control valve... sits on the backside of intake manifold with a plug going into it.
Old May 27, 2004 | 04:55 PM
vannman's Avatar
i have a 98 prelude SH... same problem. I cleaned my intake filter and cleaned out the throttle body somewhat. still has same exact problem... most noticable with the AC on. One say it is going to stall out i know it... so i should try adjusting the idle sqrew or what???
Old May 27, 2004 | 06:48 PM
dallison's Avatar
Default Re: AC and Idle Problems (vannman)
does the compressor kick on and off?
Old May 28, 2004 | 07:17 AM
abeaujuin's Avatar
I removed the IAC valve and saw alot of carbon build up in it, I cleaned it out and installed back and reset the ECU. The car runs fine now and I haven't seen that problem any more. Thanks to everyone that helped me out on this one.
Rooftop-Special
Sep 2, 2010 08:08 PM
blackludebosh
Aug 9, 2008 01:33 AM
SiTR
May 5, 2008 08:39 PM
Jeager521
Sep 12, 2003 12:28 PM
riceball777
Aug 18, 2003 10:11 AM
