Help!! SPEEDOMETER PROBLEM!!
1990 Honda Accord EX, Manual Transmission, 4 door.
My speedometer is broken. It rarley works sometimes.
I was wondering what the most expensive problem to fix a speedo would be and how much it would cost???
If anyone helps, Thank you!!!
-Rob
-Rob
Is this an automatic, or a standard? You've two threads going for the same complaint
"Service engine soon" lamp on?
If so, you could have a bad Vss
It looks like this (manual Trans)
http://www.carpartswholesale.c....html
If not, suspect the cluster itself (which is the more expensive)
P
P
