headlight question...help!
Old Jan 2, 2008 | 04:34 PM
ryanhugh7's Avatar
Default headlight question...help!
hey guys, my headlights will no longer turn on. Even when I just try to turn on the brights, the blue light in the dash doesn't work. All the other external and internal lights work without issue though. The headlights have been flashing on and off for a while now, only when the car seems to be just starting up or cold though. Today, they just stopped. I also head a ticking like sound coming from the glove box just prior to this. I checked the fuses under the hood, and they are fine.
anyone have any ideas of what this could be??
thanx so much!!!
Old Jan 2, 2008 | 04:41 PM
hondadude's Avatar
Default Re: headlight question...help! (ryanhugh7)
Without knowing the year, it's a little hard to tell you what wires you can check for power from the headlight switch.
Replace the headlight switch I guess?
Old Jan 3, 2008 | 08:22 AM
ryanhugh7's Avatar
Default Re: headlight question...help! (hondadude)
sorry it's a 94!
Old Jan 3, 2008 | 10:54 AM
YeuEmMaiMai's Avatar
pull the HL switch out and test it. if it does not pass the test, repalce it.
Old Jan 6, 2008 | 08:07 PM
propwdialogue's Avatar
Default Re: headlight question...help! (YeuEmMaiMai)
I've been having the same problem. FWIW, I could replicate the problem by jiggling the relay underneath the hood, so I'm fairly convinced that this is the culprit. however, I've been busy and the weather's been warm, so I haven't bothered to replace it yet. Once I get around to it, I'll let you know if its the fix!
kayONE
Mar 24, 2013 10:27 AM
eghatchfla
11
Jul 1, 2010 06:15 PM
K24_Y61P
Honda Civic (2001 - 2005)
11
Aug 4, 2008 07:55 PM
dumkopf
Jul 31, 2007 05:13 AM
Finest
Sep 12, 2002 06:12 AM
