intake
Old Jan 1, 2008 | 02:46 PM
poland accord's Avatar
Default intake
well i am going to install an short ram on my 5th gen . I was wondering if I should leave that tube where it hovers the battery. And if anything will it make more or less power? please i need good knowledege thanks.
Old Jan 1, 2008 | 05:20 PM
The-Kid's Avatar
Default Re: intake (poland accord)
There are no tubes over the battery. There is though a little flap. In anycase, remove the whole upper airbox. You may remove the lower airbox, but you may have to remove bumper. This is optional on SRI.
Though if you want power, you should have gone with the CAI.
Old Jan 2, 2008 | 03:57 PM
A_Rotary_Guy's Avatar
Techincally not more power. The temperature difference between where the CAI sits and where the SRI sits is approximately 7 degrees without a heat shield around the SRI, which isn't enough of a temp difference to cause any difference in power. The problem with a CAI is that it's going to pick up more dirt and grime and have a slower throttle response than a SRI because of the extra pipe length and air flow travel. The best setup for an intake would be a SRI to where the stock box sits by the fender with a heat shield built around it. This has been proven many times over on many different vehicles.
Mr. EG
Jan 20, 2011 09:36 AM
uNVmyEJ8
May 27, 2007 09:16 AM
one power
May 22, 2007 10:28 PM
young noob
Dec 24, 2005 02:19 PM
dc5r4515
13
Apr 11, 2004 09:13 PM
