Engine Coolant Sensor Replacement
Old Sep 5, 2009 | 04:35 AM
robdog09's Avatar
New User
Default Engine Coolant Sensor Replacement
Went to a Honda dealer and he told me this rogue engine code referred to my engine coolant sensor. In addition, not only did he point out the sensor is probably bad, he also told me i should probably replace the computer entirely?!?!? I think thats ridiculous.
So two questions:
1) What exactly does that sensor do (i.e. can i live with it being busted) and/or how do i replace it?
2) Do i really have to replace the computer??
Old Sep 5, 2009 | 08:11 AM
djkurious's Avatar
Default Re: Engine Coolant Sensor Replacement
1. I would go ahead and replace it, just get the part maybe from ebay or a local junkyard cheap.
2. You DON'T have to replace ECU
Old Sep 5, 2009 | 08:56 AM
robdog09's Avatar
New User
anyone have a "howto" on how to replace it?
Old Sep 5, 2009 | 02:52 PM
19Accord97's Avatar
We have no idea what you drive. So we obviously can't help you.
Old Sep 7, 2009 | 06:08 PM
robdog09's Avatar
New User
I thought it was pretty clear since i posted it in the Honda Accord (1990 - 2002) group ... but its a 2001 Accord
Old Sep 7, 2009 | 06:11 PM
19Accord97's Avatar
There are a a large portion of people who post in the incorrect forum.
Not every Accord from 1990-2001 is the same nor uses the same motor. I know where my engine coolant sensor is on my 97 but it could be different on a 97 w/ a v6.
In most cases, you can easily follow the lower radiator hose to the rear of your engine where the thermostat housing is located. On mine, the plastic plug that goes into the housing is green and that is the sensor.
Old Sep 7, 2009 | 07:20 PM
nus_dogg's Avatar
Yup, its usually on the Thermostat housing; just use the correct socket to remove the sensor out.
Old Sep 7, 2009 | 09:34 PM
fuenteselaine's Avatar
New User
Hi Robdog09,
Last year, my Accord was having same problem. I went to the Honda service centre, he repaired sensor successfully without replacing the computer. I think you should go to any other Honda dealer.
Old Sep 8, 2009 | 11:24 AM
robdog09's Avatar
New User
Ok, ill definitely try and look. Someone told me to find the bottom hose to the outlet and its there, but i dont see it. Is it a diff color? Is it on the radiator itself or on another piece separate for the radiator?
Old Sep 8, 2009 | 11:33 AM
Sales@Bisimoto.com's Avatar
its separate from the radiator.like others said it should be near/on the thermostat
and if you dont replace it the car will stay in open loop making you run rich and have poor performance all around
Old Sep 8, 2009 | 09:26 PM
oblivion2kx's Avatar
So two questions:
idk man, I think you need a new bumper.
Seriously, smack the honda guy and go to another dealership.
cruzneel
Aug 27, 2017 12:05 PM
Babong
17
Sep 20, 2011 08:35 AM
doitmyself2010
11
Jun 26, 2011 12:55 PM
