driver's side window install?
Old Nov 9, 2012 | 07:04 AM
santaclewes's Avatar
Default driver's side window install?
How much?
Old Nov 9, 2012 | 09:01 AM
h0p3l355dork's Avatar
Default Re: driver's side window install?
No information whatsoever? What car? trim? year? What's the symptoms? Did you shatter a whole window or do you just need the motor/regulator replaced?
Ball park: $20,000 plus labor.
Old Nov 9, 2012 | 09:15 AM
oversteer_ms's Avatar
x2
Old Nov 10, 2012 | 01:58 PM
Thanks for the response. I have a 1990 accord 4 door with a totally shattered front driver's side window to repair. Is it a really difficult fix? I have the replacement glass and I wonder if I need special tools to replace it myself. What do you think, Austin
Old Nov 10, 2012 | 04:41 PM
I would charge an hours worth of labor, relatively $50 plus the cost of the glass. No specialty tools are needed.
Make sure you get ALL the broken glass out of the seals and everything.
It's pretty straight forward though. If you know how to use a screwdriver, a 10mm socket and ratchet and have common knowledge on taking things apart. You can do it.
lax1089
Jul 2, 2008 10:27 AM
deerman2701
Nov 27, 2007 05:59 AM
HatefulDjiN
May 23, 2006 03:14 PM
01-0720
Aug 25, 2005 08:21 AM
RTW DC2R
Dec 24, 2002 11:03 PM
