Knock Sensor HELP
Old Nov 20, 2012 | 03:52 PM
SuperBowser707's Avatar
Default Knock Sensor HELP
I have an 01 accord ulev thats boosted. The knock sensor snapped in half a little while ago glued it back together and it snapped again. So i bought a new sensor to replace the broken one and can not get any socket on the remaining part in the block. Has anyone had this issue and got it out or is there anywhere else i can put the sensor on the block. I dont want to do that bypass thats on here by hooking it into the speakers or whatever. Any help is greatly appreciated.
Thanks
Tom
Old Nov 20, 2012 | 03:55 PM
Default Re: Knock Sensor HELP
also It appears that there is a coolant line going over half the bolt which is causing the socket to not fit on it
Old Nov 20, 2012 | 04:54 PM
Does the sensor need to be on the block or could i put it on the head
Old Nov 20, 2012 | 05:56 PM
never mind finally got the socket to fit used a different brand that was a little thinner on the sidewalls and got it off
EFjoe91
Mar 5, 2016 06:17 AM
eddisgetti1
Nov 12, 2011 09:45 PM
bb4socal
Feb 25, 2006 03:46 PM
abbas
May 2, 2005 02:23 PM
CM-R
Mar 29, 2002 12:34 AM
