Never experienced this problem before. HELP
Old Nov 20, 2012 | 03:52 PM
tweaked.crx's Avatar
Default Never experienced this problem before. HELP
Well here is my setup 92 accord with a swapped in f22a1 from a 91 accord.
The car is running rough as if on 2 cylinders. I will go into what is going on. Or more or less whats not going on.
While the car is running I can remove spark plug wires 1 and 2 from the head and the car will run the same.
I can also remove the 1 and 2 fuel injector plugs while running and still runs the same.
Things I have replaced
spark plugs
wires
cap and rotor
new dizzy
new injectors
new injector resistor box
new fuel filter
Things I have confirmed are good
Belt timing
ignition timing
Firing order
everything above.
NO CEL
Cleaned
throttle body
intake manifold
IACV
Now if I move swap plug wires 3 and 4 the problem swaps to these cylinders and 1 and 2 work perfect. if I swap them back 1 and 2 mess up again.
Also if I removed 3 or 4 plug wire or injector wire while running the car stalls out. which is what is expected.
This is kind of a hard thing to explain without talking to someone face to face. But this is my DD and I need this back about 2 weeks ago
I hope this is a ok eplanation for you
Thanks
Tim
Old Nov 20, 2012 | 10:29 PM
holmesnmanny's Avatar
Default Re: Never experienced this problem before. HELP
You're gonna need to compression test it. You can get a kit for like $20 at autozone or oreilly.
Don't forget to remove the ecu fuse to disable spark and remove the main relay to disable fuel.
Old Nov 21, 2012 | 02:40 AM
cctgene's Avatar
If moving the two spark plug wires moves the problem......................then wouldn't you suspect that those wires are the problem?
Old Nov 21, 2012 | 02:47 AM
Are you sure you got the spark plugs wires correct? It should go 1 3 4 2 with 1 starting at bottom left corner of distributor and running clockwise around distributor.
Also, number 1 cylinder is closest to drivers side fender and goes in order 2 3 4 towards passenger side fender.
Old Nov 21, 2012 | 08:35 AM
v4lu3s's Avatar
RTFM
have you take the time ot actually ohm your spark plug wires out yet and verify they are good?
Old Nov 21, 2012 | 12:28 PM
I forgot to add I did a compression test on this 190 on every cylinder.
used 3 sets of plug wires also
checked firing order about 17 times now. its the same every time haha
Figured it out on a total accident last night!!!
Turns out I had the vacuum line for the EGR in the wrong position.
I went to unplug a vacuum line to see how much idle changed and if it changed the 1 and 2 cylinder at all. Well as soon as I unplugged the EGR the car idled high which was expected. But it idled very smooth. I plugged that vacuum port and everything is perfect now. Never would have guess it was dumping too much exhaust back into the motor.
autobahn_clem
Dec 9, 2010 05:36 PM
turboef90
Oct 23, 2008 06:10 PM
Ls_eg6
Aug 4, 2008 03:14 PM
sirdeus
Nov 1, 2007 08:22 PM
CrX1988Zc
Aug 23, 2002 06:22 AM
