Dizzy help
Old Nov 16, 2012 | 01:36 PM
hondaaccordf23's Avatar
Default Dizzy help
H23 vtec 00 accord swap/ Dizzy is td60u
I installed a new dizzy but car won't start
this is the website I took the wiring off of
http://importnut.net/h22a_swap.htm
Old Nov 16, 2012 | 01:38 PM
Fliptard's Avatar
Default Re: Dizzy help
do you get spark? Wires in corect order and not backwards(Guilty of that several times)
Old Nov 17, 2012 | 01:35 AM
holmesnmanny's Avatar
Your car has the crank sensor at the oil pump, but your distributor has a crank sensor inside it(obd1). Did you have any extra wires hanging around the distributor ? It probably would have been best to just get an obd2 h22a distributor.
Old Nov 17, 2012 | 02:16 PM
My engine had the Crank, TDC, and Cylinder position sensor in the distributor. That distributor the cylinder sensor went out. All my wires are connected the same way I had them on old TD94u distributor.
With new dizzy I get spark but no start
also starts but dies right away
Old Nov 17, 2012 | 09:34 PM
td60u is an obd1 distributor.
http://www.hondapartscheap.com/parts...p-oil-strainer
Part number 18
Your crank sensor should be at the oil pump unless there was already some work done previously that you didn't disclose.
Old Nov 18, 2012 | 12:42 PM
yes that's the f23 though. my h23 vtec dizzy all sensors are inside it is labeled TD94U.
Old Nov 18, 2012 | 08:56 PM
What exactly did td60u mean as posted by you ?
Angeljavier3577
Apr 30, 2018 01:41 PM
tommygunn
Jul 14, 2010 04:53 AM
dvp95
Mar 15, 2010 02:15 PM
raidacaipo
May 18, 2009 08:57 AM
fox23
Jul 25, 2005 03:56 AM
