Difference between OBD's
Old Jan 8, 2003 | 09:49 PM
Starrman85's Avatar
Default Difference between OBD's
ok, i kno wat OBD stands for, but i'm wondering wat the difference is between OBD I and II. i did a search, but didn't find anything. which OBD is better? wat kinda OBD would be found in my 4th gen? thanks in advance.
Old Jan 8, 2003 | 09:56 PM
KTeller8's Avatar
Default Re: Difference between OBD's (STARRMAN85)
96+is obd2 so your obd1
Old Jan 8, 2003 | 09:58 PM
Starrman85's Avatar
Default Re: Difference between OBD's (KTeller8)
k, that answers one of my questions, thanks! but the other is which one is better and wat the differences r between I and II. if one is better then the other.
Old Jan 9, 2003 | 04:45 AM
Stew Pidasso's Avatar
OBD I is generally considered better from a performance/tuning point of view. Please use the search feature...Taken from...
https://honda-tech.com/zerothread?id=372033
Quoted from the web...
OBD I
ON BOARD DIAGNOSTICS (OBD)
WHAT IS IT AND WHAT DOES IT MEAN TO YOU?
by Fred Bordoff
OBD, or on board diagnostics, was first introduced by General Motors in 1981. The purpose of ‘OBD’ was to monitor the emission control system in the car. When the computer system of the car sees a fault in the emission control system, three things are supposed to happen. First, it would set a warning light on the dashboard, to inform the driver that a problem existed. Second, to set a code in the computer. Third to record that code in the computer’s memory, that can be later retrieved by a technician for diagnosis and repair.
This system worked so well, in 1986 California mandated that all cars sold in the state be equipped with ‘OBD’. This then became an industry standard throughout the nation, and all cars sold in the nation had some form of ‘OBD’
This first version of ‘OBD’ had a lot of shortcomings. First, it only covered the engine emission system. The fuel tank vapors were not monitored. The exhaust emissions were not measured. And only devices specifically installed for emission control were monitored. Second, there was no standardization throughout the industry. Each manufacturer had a different term for the warning light that was illuminated when a fault was determined. GM called it a ‘check engine’ or ‘service engine’ light. Chrysler called it a ‘power loss’ light. Ford called it an ‘engine’ light. Most foreign cars called it a ‘check engine’ light. This was not only confusing to the technician, but also to the motorist. Many motorists upon seeing the ‘service engine’ light illuminated, brought their car to a repair facility and either asked for an oil change or tune-up, expecting the light to go out. Needless to say, this did not happen, and after spending unnecessary money on service work, the system then had to be diagnosed and repaired. The coding system for each manufacturer was also different making diagnosis much tougher.
The clean air act of 1990 mandated that beginning with the 1996 model year, all cars sold in the U.S. be equipped with a new version of on board diagnostics This system became known as OBD II. The manufacturers beat the deadline and almost all cars were equipped with OBD II in the 1995 model year. If your car is a 1995 model or newer, chances are it is equipped with OBD II.
Among the many differences between OBD and OBD II, was the standardization of the system. All dashboard warning lights now say ‘check engine’, usually with a picture of an engine with the word ‘check’ across it. The coding system is now standard. There are now over 400 possible trouble codes that can be stored in the system. All causes of excessive are now monitored. If the gas cap is left loose and vapors are escaping from the gas tank, the ‘check engine’ light will be illuminated and a code will be set. It is extremely important now that the engine be shut off when refueling the vehicle. Another big difference between the systems is that with OBD when a fault is seen the warning light is illuminated and a code set. The warning light will then go out when the fault is no longer seen, but the code will be set and retained in the computer’s memory. In OBD II systems the light does not go out until the fault is repaired and reset by the technician. This can create two problems for the motorist, first, if the warning light is set because of a loose gas cap, it will not go out when the cap is tightened. The car will have to be brought to a service facility to reset the light, at a cost to the motorist. Second the danger exists that when the car is brought into a repair facility, the technician might reset the light without actually repairing the fault. In this case the light will come back on again.
It is important that the motorist be aware of the ‘check engine’ light, as well as all other dashboard warning lights and what they mean. This knowledge will help eliminate unnecessary costs due to unnecessary repairs. When any dashboard warning light comes on, check the owners manual before bringing the car to a repair facility.
OBD II
On-Board Diagnostic (OBD) systems are self-diagnostic systems incorporated into the computers of new vehicles. All 1996 and newer vehicles less than 14,000 lbs. (e.g., passenger cars, pickup trucks, sport utility vehicles) are equipped with OBD II systems, which are California's second generation of OBD requirements. The OBD II system monitors virtually every component that can affect the emission performance of the vehicle to ensure that the vehicle remains as clean as possible over its entire life, and assists repair technicians in diagnosing and fixing problems with the computerized engine controls. If a problem is detected, the OBD II system illuminates a warning lamp on the vehicle instrument panel to alert the driver. This warning lamp typically contains the phrase Check Engine or Service Engine Soon (see below). The system will also store important information about the detected malfunction so that a repair technician can accurately find and fix the problem.
Old Jan 9, 2003 | 10:29 AM
Starrman85's Avatar
Default Re: Difference between OBD's (Stew Pidasso)
ey, thanks for the info. i did a search, but i didn't seem to find anything that helped, but i guess i didn't do a good enough search. anywayz, thanks for the info and clearing that up, cuz i always hear ppl talking about OBD I and OBD II, and was wondering wat it was. thanks
Old Jan 9, 2003 | 06:33 PM
cjo_28's Avatar
You could write a small book on the subject but basically, OBDII is a federal standard (in the states) set into place in 1996. OBDII will now monitor the vehicles emissions and set a SES/CEL light with an emissions failure (OBDI couldn't care less). Even though OBDII is supposed to be a standard, there are small differences between manufactures and model years.
Overall, it could be a little harder to modify OBDII vehicles because the ECM monitors so many different types of engine/trans data and could possibly try to compensate for any mods you make or at least set the SES/CEL light. If you’re familiar with a scan tool, you'll probably be happier with the OBDII system because you are able to monitor all of this data.
kiDchaos
Northeast (Sales)
Nov 9, 2013 12:54 PM
jdtphotography
Mar 3, 2007 06:54 PM
hector85
Jun 17, 2005 05:54 PM
SQURL
Dec 23, 2004 08:41 AM
the JigGa mAn
Jul 1, 2003 08:57 PM
