headlight assyembly
Old Jan 1, 2003 | 05:47 PM
zzzhondazzz's Avatar
Default headlight assyembly
How do i remove my whole thing?
Old Jan 1, 2003 | 06:38 PM
ratherbewalking's Avatar
Default Re: headlight assyembly (zzzhondazzz)
what year?
Old Jan 1, 2003 | 06:42 PM
ArchAngel Sabastian's Avatar
New User
have fun if its a 5th gen
Old Jan 1, 2003 | 06:55 PM
95sihb's Avatar
Default Re: headlight assyembly (ArchAngel Sabastian)
yeah the 5th gens are so much fun to take off.................
lets say there is 2 easy bolts and 1 easy clip and 3 pain-in-the-*** bolts that you will have to take off.
Old Jan 2, 2003 | 10:03 AM
flrdaccrd's Avatar
sledgehammer
Old Jan 2, 2003 | 12:49 PM
Meisoslow's Avatar
Default Re: headlight assyembly (flrdaccrd)
Very Carefully
Old Jan 2, 2003 | 12:58 PM
93accordEX's Avatar
I think 4th 5th and 6th gens all require taking off the bumper. so first find out how to do that. consult a manual for your car.
Old Jan 2, 2003 | 01:27 PM
its a 95
Old Jan 2, 2003 | 01:59 PM
Dumplings's Avatar
Yea I've done it before. First take off your front bumper. This includes the bolts on the bottom, and 2 bolts holdin inside the signal lites on each side. Pull out the bumper and then dissemble the healight housing. There should be a total of 5-6 bolts holdin on each headlight housing.
Before u dl all this, u probably want to disconnect ur battery and all the bulb wires. Make sure u work in a clean area, so when u take out the housing, no dust will get inside the housing.
Old Jan 2, 2003 | 02:10 PM
New User
Default Re: headlight assyembly (Dumplings)
the only prob i found when taking of the bumper is that there are two clips under each headlight that hold the bumper on soo...
to remove headlight remove bumper..
to remove bumper remove headlight..
Old May 3, 2003 | 11:46 AM
twkdCD595's Avatar
old topic but bump cause you cannot get it off without take out the headlight?!!!?
Old May 3, 2003 | 01:53 PM
H22 CD5's Avatar
what i've done to my car and several other 5th gens is get to the underside of those tabs underneath the headlight with a pair of wire snippers and demolish those tabs and leave them out. those tabs do not really provide any REAL reinforcement of the front bumper so out and away they go.it'll be alot easier for you in the future if you plan on removing the front bumper again.
Old May 3, 2003 | 01:56 PM
iam7head's Avatar
Default Re: (H22 CD5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22 CD5 &raquo;</TD></TR><TR><TD CLASS="quote">what i've done to my car and several other 5th gens is get to the underside of those tabs underneath the headlight with a pair of wire snippers and demolish those tabs and leave them out. those tabs do not really provide any REAL reinforcement of the front bumper so out and away they go.it'll be alot easier for you in the future if you plan on removing the front bumper again.</TD></TR></TABLE>
let's do thing the right way..I am sure we can take the headlight off without too much problems. I dont know it just me or what, i hate to do something to my car that can't go back to stock. once you tear the tap you will never have it again, why not spend like 10 more min and have everything perfect? just my two cents.
nomoshing
May 11, 2008 03:25 PM
JohnD1079
Jan 21, 2007 02:00 PM
thegeorge613
Sep 19, 2006 10:55 PM
95PreludeSi
Jul 20, 2005 08:21 PM
SOmbody
May 7, 2004 12:36 PM
