ecu code 41
Old Apr 9, 2003 | 07:11 AM
rrei's Avatar
Default ecu code 41
Primary Oxygen Sensor Heater Malfunction
thats the code, how do i fix it, changing the o2 sensor would not work and the ecu was changed same problem. my airfuel guage from summit is hooked up to the o2 line ---help
Old Apr 9, 2003 | 07:25 AM
JimBlake's Avatar
Default Re: ecu code 41 (rrei)
That's just the heater circuit, not the sensor itself. So you've already changed the sensor (heater element is built-in). There should be a fuse somewhere, otherwise you gotta chase down some broken wiring somewhere. Check to see if the heater wires get 12v power, & go on from there. Did you break the heater circuit when you wired in your A/F gauge?
Old Apr 9, 2003 | 08:01 AM
rrei's Avatar
Default Re: ecu code 41 (JimBlake)
yeah i did, im sure of it
Old Apr 9, 2003 | 08:04 AM
carolinaACCORD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rrei &raquo;</TD></TR><TR><TD CLASS="quote">yeah i did, im sure of it</TD></TR></TABLE>
that's probably the problem then.
Old Apr 9, 2003 | 08:10 AM
rrei's Avatar
Default Re: ecu code 41 (carolinaACCORD)
but how i fix it, run a new wire, where would the fuse be located if there is one. im not sure which wire it is
Old Apr 9, 2003 | 12:29 PM
JimBlake's Avatar
If you find where you cut the wrong wire, then just splice it together. I don't know what year Accord you have, so I don't know which fuse. Maybe its listed on the fusebox lid?
Old Apr 9, 2003 | 01:20 PM
rrei's Avatar
94 lx thanks
NZDelsoldude
Jan 24, 2007 05:16 PM
vtec25
Mar 14, 2006 02:39 AM
JDM_SOHC
31
Aug 18, 2005 06:10 AM
Eucalyptus lude
Jun 3, 2005 01:42 PM
lawlerlaw
12
Feb 29, 2004 08:02 AM
