cooling problem
Old Apr 8, 2003 | 08:03 PM
jhwells's Avatar
Default cooling problem
i have a 2001 honda accord and when i bought it new it ran temp wise in between the cold mark and the middle mark....now with 39000 miles on it it runs at the middle mark and a little over.....what do you think is the problem.....the fans work and i just serviced the radiator with honda coolant....thanks
Old Apr 8, 2003 | 08:05 PM
Cseika02's Avatar
Default Re: cooling problem (jhwells)
check ur thermostat.... if itz ok u might need a new water pump...
Old Apr 8, 2003 | 08:07 PM
Razor's Avatar
sounds like your thermostat could be stuck closed, causing the temp to be higher. my thermostat was stuck open, not letting the car reach proper operating temperature.
Old Apr 9, 2003 | 02:52 AM
niedejb's Avatar
Default Re: cooling problem (Razor)
There is air in the system and it needs to be bled out.
Can you clarify on "just serviced"?
tony97
Apr 17, 2013 12:33 PM
tech410
15
Sep 22, 2010 05:22 AM
mn_babyboy
May 17, 2008 05:46 AM
helldriver88
Jan 26, 2008 10:33 PM
rob_honda
Apr 1, 2004 04:05 AM
