engine code question.... f22b????
Old May 29, 2003 | 04:20 PM
honda8882's Avatar
Default engine code question.... f22b????
I have a f22b1, at least i thought thats what it was when i bought it. On the engine block it says f22b and thats it, but i know the motor is vtec. anyone want to help me out. i believe the motor is japanese because i bought it from a japanese importer. what motor is this???
thanks
Old May 29, 2003 | 05:31 PM
sauceman's Avatar
Default Re: engine code question.... f22b???? (honda8882)
F22B is a twin cam. Is yours that way?
Old May 29, 2003 | 07:10 PM
hanginlow's Avatar
Default Re: engine code question.... f22b???? (sauceman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceman &raquo;</TD></TR><TR><TD CLASS="quote">F22B is a twin cam. Is yours that way? </TD></TR></TABLE>
f22b1 is a sohc vtec, f22b2 is the sohc non-vtec. If your vin number starts with a "J" then it is japanese manufactured, otherwise it will probably say "1" in the begging. This will tell you which you motor is....jdm, or usdm.
Old May 29, 2003 | 07:51 PM
honda8882's Avatar
Default Re: engine code question.... f22b???? (boostedf22)
mine is sohc. do u think the place swapped the bottom end from a dohc?
Old May 29, 2003 | 08:45 PM
sauceman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda8882 &raquo;</TD></TR><TR><TD CLASS="quote">mine is sohc. do u think the place swapped the bottom end from a dohc?</TD></TR></TABLE>
No then it's the F22B1 you got.
Old May 29, 2003 | 08:57 PM
One2chi's Avatar
yep
Old May 30, 2003 | 04:24 AM
honda8882's Avatar
Default Re: engine code question.... f22b???? (One2chi)
these are the numbers i see
b42170384c
3004754
the numbers above come form above and below the f22b tag
i also saw this number a few inches under where the header attaches
3d0217023c
im still confused as to why it only says f22b if i have sohc vtec which is f22b1. can anyone shed some light on this
Old May 30, 2003 | 08:53 AM
f22a's Avatar
well, for example, jdm h22a's just say "h22a" rather than h22a1 or h22a4, all of the jap f22 motors i have seen have been the same way - no trailing number.
Mr. EJ1
19
Jul 16, 2008 08:37 PM
sixfiveoh
Sep 12, 2006 01:21 PM
98JDM_Type_R
Sep 2, 2004 05:13 PM
slow_yota
Aug 29, 2004 07:33 AM
Toxic H
Feb 5, 2004 08:25 PM
