Got a cel code 41 - need advice !!
Old May 30, 2003 | 06:55 AM
Accord97Owner's Avatar
Default Got a cel code 41 - need advice !!
What do I have to do to fix get rid of this code.?
Would changing the primary o2 sensor do the trick ?
Any help will be appreciated
Old May 30, 2003 | 09:29 AM
JimBlake's Avatar
Default Re: Got a cel code 41 - need advice !! (Accord97Owner)
That code is for the heater built into the O2 sensor. Might be a blown fuse for the heater circuit, I'd check that first. Someone who has a 5th-gen should be able to tell you which fuse it is.
If the fuse is good and there's 12v at the heater power wires, then it's the heater which is built into the O2 sensor.
Old May 30, 2003 | 04:34 PM
Chiovnidca's Avatar
Default Re: Got a cel code 41 - need advice !! (JimBlake)
The heater circuit of the sensor should measure about 4 to 10 ohms.
Old May 31, 2003 | 03:41 AM
Where can I find the fuse??
I've been looking all over the car, read the owner's manual and can't find the fuse.
Old May 31, 2003 | 07:31 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord97Owner &raquo;</TD></TR><TR><TD CLASS="quote">Where can I find the fuse??
What year and model?
Old May 31, 2003 | 11:02 AM
Default Re: Got a cel code 41 - need advice !! (Chiovnidca)
Accord 97 LX 4 door
Old Jun 1, 2003 | 04:32 AM
Chiovnidca's Avatar
It's fuse 33 in the underhood fuse box. (ECU fuse.)
Have you checked the resistance of the heater?
Old Jun 1, 2003 | 05:01 PM
The fuses are fine.
I'm afraid that the heater circuit is open and have to change the O2 sensor...
I'm leaving the car at the shop tomorrow and let you know what happened
Old Jun 1, 2003 | 05:43 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord97Owner &raquo;</TD></TR><TR><TD CLASS="quote">I'm afraid that the heater circuit is open and have to change the O2 sensor... </TD></TR></TABLE>
That's usually the problem with a code 41.
Old Jun 2, 2003 | 08:51 AM
Got a call from the shop...
Gotta change the sensor ...
The worst part is the cost -&gt; 357U$S !!!! (yes.. it's Argentina where I live and imports are dear but this has gone too far !!!)
I'll definitely buy the sensor myself and see if I can change it.
Is it hard to change this thing??
Old Jun 2, 2003 | 02:13 PM
Chiovnidca's Avatar
Is it hard to change this thing?? </TD></TR></TABLE>
Not usually. Every once in a while I get a tough one.
Keevin77
Oct 28, 2011 06:18 PM
jrami020
Oct 18, 2009 02:24 PM
Cashbrun
Oct 1, 2005 09:47 PM
bgod
Jun 5, 2003 09:50 AM
