Odd Engine Problem
Old Jun 3, 2003 | 06:30 PM
Conechaser's Avatar
Default Odd Engine Problem
As some of you may know, i recently put a '96 LX block w/ a '95 EX head in my '94 Accord EX. Everything is running fine, except for one problem. When i 1st turn the car on, after it has cooled down, the car runs fine, vtec works, etc. However, after 10-15mins of driving, the car will not engauge vtec and cuts out sort of like it is hitting a rev limiter, but not quite, @ ~5krpms if the car is in gear, if i clutch in or put it in neutral, i can rev it to ~5.5krpms. I have CELs, no lights what so ever, so i have no clue what would cause this problem, any suggestions?
Old Jun 3, 2003 | 08:16 PM
fastaccord94lx's Avatar
I'm not expert, but I am guessing this has something to do with the ECU. Are you sure you got everything in the right jumper?
Old Jun 3, 2003 | 08:22 PM
If it isn't engaging it could be a problem with the MAP sensor or something, but I'm not sure why it wouldn't let you keep revving past 5k.. hrmm there is a VTEC lock up valve see if that is working properly. I'm doing my best man to give you suggestions man! :b
qhiggy
Feb 4, 2013 12:22 PM
tundra2000
Apr 14, 2011 12:25 PM
DJGvtec95
Feb 28, 2009 04:29 AM
kenbo21
Honda Civic (2001 - 2005)
Sep 11, 2008 10:20 AM
integraluva04
Jun 29, 2008 10:27 AM
