Need help quick!!!! Please!!!!!
Old May 26, 2003 | 02:25 PM
kasper's Avatar
Default Need help quick!!!! Please!!!!!
Okay, thanks in advance to anyone who can give me some ideas before I go spend a bunch of money I don't need to.
I have a jdm h22a and this morning I went out and started it nothing out of the ordinary happened. I let it warm up like always before I left to go to work. I pulled out of my driveway and got about a half mile down the road and it started sputtering. When I push the gas it goes but no where near to how it should. It just continuously(i guess the noise could be described as sputtering. Kinda like its not firing on all 4 cylinders. Could a bad plug or wire be contributing to this or is it something more serious!?????! I hope nothing too bad. Thanks for the help guys!
Old May 26, 2003 | 02:51 PM
Conechaser's Avatar
Default Re: Need help quick!!!! Please!!!!! (kasper)
Check your oil lever, then replace plugs/wires and see it still does it.
Old May 26, 2003 | 03:12 PM
92 ex-r's Avatar
make sure it is firing on all 4 cyl.
Old May 26, 2003 | 03:17 PM
sauceman's Avatar
Do you get a CEL, or it just sputters?
Check out plugs, wires, dist cap.
If you have a CEL, you should get it jumped, it would give you an answer.
It could also be a bad fuel/air mix due to bad O2 sensor.
Old May 26, 2003 | 03:24 PM
kasper's Avatar
Default Re: Need help quick!!!! Please!!!!! (sauceman)
I checked the engine codes and its not pulling any other than the one it has pulled since the swap and that code doesn't exsist. I had a bad 02 sensor when I did the swap and it pulled a code so it was replace maybe a month and a ahlf ago so it shouldn't be bad.
sailingstu05
Jan 2, 2010 06:55 AM
smoovekriminal
Aug 17, 2007 09:55 PM
E_LOW
Feb 6, 2006 05:15 PM
only1crx
Mar 6, 2005 02:58 PM
D-SPEED
Sep 1, 2001 10:58 PM
