ecu code 80 need help?
Old Jun 25, 2003 | 06:13 AM
brega3's Avatar
Default ecu code 80 need help?
I just check my ecu and throwing a code 80 I think it is "Exaust Gas Recirculation Insufficient Flow" What exactly is this and how do I fix it? Thanks in an advance
I'm confused hold on. When I checked the ecu it gave 8 long flashes and paused and kept on giving me 8 long flashes, is that a code 80 or a code 8?
Modified by brega3 at 3:34 PM 6/25/2003
Old Jun 25, 2003 | 07:39 AM
Accord_Munch's Avatar
Default Re: ecu code 80 need help? (brega3)
It is probably code 80 ... I just had it myself, you can try resetting your ECU to see if it goes away. Mine went on when I was up in Flagstaff, higher elevation, it was colder out, and my VAFC probably had something to do with it. When I got home, after finding out what the code was, I reset my ECU and the check engine light has not come back on in two weeks. You could always go to Autozone and they can read your code for free. BTW I have the same car ..
Old Jun 25, 2003 | 10:04 AM
brega3's Avatar
Default Re: ecu code 80 need help? (Accord_Munch)
by reseting it, you mean to disconect the negative pole of the battery? and what mods do you have in your car to be doing high 15's the 1/4 mile?
Old Jun 26, 2003 | 05:32 AM
brega3's Avatar
Hey I reseted the ecu yesterday it went away for the whole day and then it came back on this mourning.... What do I do to fix this thing?
Old Jun 26, 2003 | 02:20 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brega3 &raquo;</TD></TR><TR><TD CLASS="quote">Hey I reseted the ecu yesterday it went away for the whole day and then it came back on this mourning.... What do I do to fix this thing?</TD></TR></TABLE>
Clean out the EGR ports.
Old Jun 26, 2003 | 03:26 PM
brega3's Avatar
Default Re: ecu code 80 need help? (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Clean out the EGR ports. </TD></TR></TABLE>
I don't what are the EGR ports... Can someone please point which one are they or atleast let me know what EGR stand for so I can look for it. Thank you
Old Jun 29, 2003 | 06:29 AM
brega3's Avatar
anyone?????
Old Jun 29, 2003 | 08:37 AM
Chiovnidca's Avatar
I don't what are the EGR ports... Can someone please point which one are they or atleast let me know what EGR stand for so I can look for it. Thank you</TD></TR></TABLE>
Exhaust Gas Recirculation. If it's a 5th gen there is a plate on top of the intake manifold behind the injectors. Just take it off and clean out all the carbon. Make sure to clean out the holes in the intake.
Old Jun 29, 2003 | 12:03 PM
brega3's Avatar
Exhaust Gas Recirculation. If it's a 5th gen there is a plate on top of the intake manifold behind the injectors. Just take it off and clean out all the carbon. Make sure to clean out the holes in the intake. </TD></TR></TABLE>
Any specific tool to clean the whole with???
Old Jun 29, 2003 | 01:22 PM
Chiovnidca's Avatar
Any specific tool to clean the whole with??? </TD></TR></TABLE>
A small screwdriver or a drill bit work well.
Old Jun 30, 2003 | 03:43 PM
brega3's Avatar
thanks...
jltucker31
Mar 9, 2009 03:50 PM
MelloYelloCRX
Jul 22, 2006 05:17 PM
