check engine light
Old Jun 24, 2003 | 11:38 AM
Jackalassassin78's Avatar
Default check engine light
How do you reset the check engine light in a 1997 honda accord lx? I found what the problem was and the honda place i took my car to wanted 60 bucks to reset it, even though i fixed the problem.
Old Jun 24, 2003 | 11:45 AM
carolinaACCORD's Avatar
Default Re: check engine light (Jackalassassin78)
pull out the 7.5 amp Radio/Back up fuse from the underhood fusebox, and disconnect the negative battery cable for ~7min.
when you crank it back up, dont touch the accelerator for 5 min.
Old Jun 24, 2003 | 12:02 PM
iam7head's Avatar
Default Re: check engine light (carolinaACCORD)
is it a hardcode or a softcode?
Old Jun 24, 2003 | 12:11 PM
Default Re: check engine light (iam7head)
not really sure what you mean by hardcode or softcode, the code was a p1956 it meant that my gas cap wasn't on tight enough.
Old Jun 24, 2003 | 01:13 PM
fluxion's Avatar
amin n'rangwa edanea
$60 to reset it? wtf? well, you can do it by either taking out the ecu fuse, or unplugging the battery. I usually wait about 5 min. before I put it back in to be sure, but you probably don't have to. That's it. After you reset it though, leave the car running and don't touch the throttle for about 5 min. so the ecu can recalibrate.
Old Jun 24, 2003 | 01:15 PM
fluxion's Avatar
i just realized I repeated the exact same thing carolinaACCORD said earlier, next time i'll read the whole thread first =P
Old Jun 25, 2003 | 08:44 AM
Thanks to everyone that responded to my post, A special thanks to CarolinaACCORD, it worked like a charm. thanks again to all.
lemdog
Nov 13, 2018 05:00 PM
welp
Aug 8, 2008 04:25 AM
rosyjazz
May 4, 2007 08:51 PM
k20EP3
22
Dec 8, 2006 12:09 PM
hondaracin24
Oct 19, 2004 09:22 AM
