bouncing tach
Old Oct 1, 2003 | 03:25 PM
jweller's Avatar
Default bouncing tach
my tach has been bouncing around independant of engine RPM. no mis-fires or anything. any ideas? ICM maybe?
Old Oct 1, 2003 | 04:27 PM
mwkirchner's Avatar
Default Re: bouncing tach (jweller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jweller &raquo;</TD></TR><TR><TD CLASS="quote">my tach has been bouncing around independant of engine RPM. no mis-fires or anything. any ideas? ICM maybe?</TD></TR></TABLE>
You may possibly have a coil acting up. Honda had a bulletin out about this issue on the V6's ... but could also be happening on a 4 cylinder.
Old Oct 2, 2003 | 04:16 AM
jweller's Avatar
Default Re: bouncing tach (mwkirchner)
I've got a MSD coil with ~~maybe~~ 5k on it. no MSD box, just the coil. I thought I was having problems before, so I replaced the stock coil with the MSD.
wouldn't a bad coil cause a misfire? It's not missing at all. usually does it at highway speed, light load, and around 2k - 3k RPMs
Old Oct 2, 2003 | 05:17 AM
03 civic si hb's Avatar
i had the same problem in my 93 GSR, it did it on the highway first thing when the engine was cold. once the car heated up it was fine, i never found out what it was, sorry can't help ya any.
Old Oct 2, 2003 | 05:53 AM
jerseybrandon's Avatar
check your connections at the distributor
sorrule
Jun 28, 2007 04:31 PM
messeduprex
May 15, 2006 03:12 PM
downingracing
Sep 14, 2004 06:24 AM
andlude
Mar 21, 2003 05:47 PM
