Start then immediate stop.
Old 10-14-2003, 04:38 PM
reddigitaldragon's Avatar
Default Start then immediate stop.
89 accord lxi, sometimes when i start the car it seems successful but then stalls. It seems to be random.
Old 10-15-2003, 04:14 AM
StimpyBoy's Avatar
Default Re: Start then immediate stop. (reddigitaldragon)
If the car also occasionally will crank nice and fine but won't start, then it sounds like a main relay problem. Mine would start and then immediately stop as there was only enough fuel delivery to get it started.
Search for main relay, and check for the fuel pump priming when you turn the key to the on position when it refuses to work (have someone listening at the gas cap for instance).
Old 10-15-2003, 05:12 AM
JimBlake's Avatar
Default Re: Start then immediate stop. (StimpyBoy)
It could also be a bad ignition switch.
Old 10-15-2003, 02:35 PM
From what I have been find on the internet I'll go for the main relay approach first. I'll post the results. Thanks
Old 10-20-2003, 08:14 AM
Re-soldered some points on the circuit board. Seems to be working fine.
collkid
13
09-16-2015 09:10 PM
My_EFsedan
09-20-2009 09:27 PM
Lightsped
01-15-2009 10:12 PM
phique2000
05-13-2008 04:23 PM
White98LS
07-14-2007 07:46 AM
Quick Reply: Start then immediate stop.
