pcv
Old Dec 9, 2003 | 04:15 PM
david90's Avatar
Default pcv
why does squeezing the pcv tube shut make clicking sound?
Old Dec 9, 2003 | 04:19 PM
mwkirchner's Avatar
Default Re: pcv (david90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david90 &raquo;</TD></TR><TR><TD CLASS="quote">why does squeezing the pcv tube shut make clicking sound?</TD></TR></TABLE>
So you know it is working. There is vacuum in that hose and the clicking you hear is the check valve in the PCV valve. If you squeeze it and hear nothing ... it is clogged.
Old Dec 9, 2003 | 04:46 PM
david90's Avatar
so why does the valve click when u squeeze the hose? Mechanically speaking
Old Dec 10, 2003 | 05:42 AM
jweller's Avatar
Default Re: (david90)
heres a good diagram about how a pcv valve works
http://www.autoshop101.com/forms/h63.pdf
and if you get really silly and want to know more than anyone really should about your pcv system, check out this thread
https://honda-tech.com/zerothread?id=697502
and if you want the quick version....
a pcv valve is a check valve. it only allows flow in one direction. when it is under vacume, it opens up. when you clamp the hose, you remove the vac source. the click is the sound of the valve closing
dk127
May 14, 2007 02:15 PM
vtec.dc2
Oct 15, 2006 10:19 AM
Blown90hatcH
Sep 26, 2001 06:35 PM
Evil DOHC
Sep 24, 2001 04:36 PM
