Replacing clock light
Old Dec 8, 2003 | 04:39 PM
alexanderia's Avatar
Default Replacing clock light
The light in the clock on my 02 Accord has burned out. Can someone give directions for replacement or do I have to go a dealer?
Old Dec 8, 2003 | 05:34 PM
AngryTroll's Avatar
Default Re: Replacing clock light (alexanderia)
The clock assembly is held in with a couple of stubborn clips. You just pull it out but it's easy to knick the trim, so be easy (I have a set of plastic tools I use to pry it out without scratching anything). As far as I know, the bulb is only available at the dealer so go ahead and call ahead and ask how much they charge to install the bulb. Some dealers will replace it with no labor charges if it's out of warranty since it's such a common problem (the new bulb is an updated part).
Old Dec 9, 2003 | 01:26 PM
IvTecR's Avatar
Default Re: Replacing clock light (AngryTroll)
the bulb was a couple of dollars at the dealer, very easy to install, just pull out the clock and hazard button out, take the two plugs out in the back for the clock and hazard, then use your fingers to turn the little dime size circle near the side and the clock light bulb will pop out, then change it
audi8t721
Aug 17, 2012 07:02 PM
Extreez
Sep 15, 2006 07:57 AM
SuNDaY DRiVeR
Aug 26, 2005 02:18 PM
Cuong-nutz
Apr 8, 2005 11:41 AM
Caveman74
Sep 3, 2004 04:29 PM
