Really wierd problem
Old Dec 19, 2003 | 10:33 AM
Mason Dixon
Guest
Posts: n/a
Default Really wierd problem
I was driving down the road yesterday, doing about 80 when my 5th gear slipped out. I can't put the car back into 5th at all. What could be causing this?
Old Dec 19, 2003 | 10:43 AM
p0pe's Avatar
Default Re: Really wierd problem (Mason Dixon)
Can you still reverse?
Old Dec 19, 2003 | 11:02 AM
Monkey Fing a Coconut's Avatar
has it been grinding for a while??? if it has and now it wont stay in gear it could be your syncros, thats wut happened to my 3rd and then 4th
Old Dec 19, 2003 | 12:48 PM
Mason Dixon
Guest
Posts: n/a
i've got full use of all the other gears. no grinding. nothing to indicate that this was going to happen. it just happened out of the blue on the highway
Old Dec 19, 2003 | 12:50 PM
Mason Dixon
Guest
Posts: n/a
i've just gotten advice that it could be my synchros are bad.....what are those and how do i fix those?
Old Dec 19, 2003 | 02:05 PM
CmptchAV6's Avatar
Default Re: (Mason Dixon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mason Dixon &raquo;</TD></TR><TR><TD CLASS="quote">i've just gotten advice that it could be my synchros are bad.....what are those and how do i fix those?</TD></TR></TABLE>
Syncros are inside the transmission and allow you to switch gears without having to rev match. If you have ever tried to switch into revers while rolling you will notice a grinding noise. That is caused by the lack of a syncro on the reverse gear. Since you do not need to switch into reverse at speed it isnt nessasary to put a syncro on that gear.
Now for the replacing part. They are inside the transmission near the teeth that enguage gears. Unless you are very knolegable on cars and the workings of a transmission I would not attempt to replace these by yourself as you will have to pull the transmission off the car take it apart replace the syncros and then put it back together and back on the car. If you do not feel comfortable doing this either take your car to a tranny shop or see if you can find a new manual tranny for your car. You can probably find a tranny for about the same price as the work will cost replacing the syncro.
CR3X
13
Oct 25, 2007 01:56 PM
allmotorhatch
Jul 31, 2006 11:10 PM
Unidentified
May 29, 2006 10:55 AM
cr0c0
Nov 2, 2005 06:05 AM
dabiddan
Nov 20, 2004 12:12 PM
