ABS problem
Old Dec 11, 2003 | 05:52 PM
blackaccord96's Avatar
Default ABS problem
hey,
I was wondering my abs light is on. I checkes all the fuses under the hood and found nothing bad there. I want to know what should i do with the relay? is there a way that I check that or what. Also is there any sensors that i should check? if this isnt something that i cant figure out would it be expensive to be taken somewhere. Can anyone help me with this problem thanks for the help
Old Dec 12, 2003 | 09:54 AM
.bagged's Avatar
Default Re: ABS problem (blackaccord96)
check your reservoir and make sure you are full. then check you relay...also in ther trunk is the main control unit check your connections sometimes they can come loose....
Old Dec 12, 2003 | 02:35 PM
dougieb3's Avatar
ABS module is electronic if tour resevour is full and still have this problem you will have to have a mech. with a computer electronically bleed the breaks. Mine is at the shop now doing this. It could also be the module box for the ABS. That is not cheap. Good Luck
Old Dec 12, 2003 | 02:49 PM
RotaryBzzzz's Avatar
Default Re: ABS problem (dougieb3)
Old Dec 12, 2003 | 03:18 PM
Default Re: ABS problem (bagged93accord)
oh ok but is there a special way you have to check the relay?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagged93accord &raquo;</TD></TR><TR><TD CLASS="quote">check your reservoir and make sure you are full. then check you relay...also in ther trunk is the main control unit check your connections sometimes they can come loose....</TD></TR></TABLE> where at in the trunk is that? thanks alot for the help people
Old Dec 12, 2003 | 03:21 PM
.bagged's Avatar
as you open your trunk it will be connected to the right hand side behind the trim pieces. pull them back and check. i just removed my abs out of my car so if anyone needs parts i am ready to ditch for no charge....
Old Dec 12, 2003 | 03:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagged93accord &raquo;</TD></TR><TR><TD CLASS="quote">as you open your trunk it will be connected to the right hand side behind the trim pieces. pull them back and check. i just removed my abs out of my car so if anyone needs parts i am ready to ditch for no charge....</TD></TR></TABLE> thanks alot i will check that and is there anything else i should do if that fails or doesnt do the trick?
Old Dec 12, 2003 | 03:30 PM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackaccord96 &raquo;</TD></TR><TR><TD CLASS="quote"> thanks alot i will check that and is there anything else i should do if that fails or doesnt do the trick? </TD></TR></TABLE>
there are to many variables with abs to say yes or no you will just have to try...
Old Dec 12, 2003 | 03:41 PM
tight
irideslammed5021
Feb 25, 2010 06:05 AM
Bsharpe
May 8, 2009 03:33 AM
JDM_is_overrated
Sep 21, 2008 12:54 PM
jkmacken
Oct 21, 2005 06:02 AM
haggard hatch
Apr 17, 2002 11:44 PM
