New Spark Plugs
Old Dec 10, 2003 | 04:14 PM
fw190bvi's Avatar
Default Ignition + Plugs
i pulled my plugs today, and as i expected, theyre shot......just from wear thankfully........my ? is what brand should i go with......ovbiously OEM is good....but NGK are apparently just a good, as NGK manufactures most sp's for honda.....or so i hear.....i realize that as long as its quality, 9/10 a spark plug is a spark plug....unless uve got an AM ignition....but im just wondering what ya'll would recomend....also, im planning on getting some new OEM wires......cause mine are kinda old and actually have holes in the cap......
Modified by fw190bvi at 8:39 PM 12/10/2003
Old Dec 10, 2003 | 05:03 PM
StimpyBoy's Avatar
Default Re: Ignition + Plugs (fw190bvi)
NGK coppers or iridiums are my plug of choice.
NGK OEM wires are also pretty good.
Old Dec 10, 2003 | 07:28 PM
D21X's Avatar
Default Re: Ignition + Plugs (StimpyBoy)
platinum is fine. dont pay over $5 per spark plug!!! iridiums just arent worth it
Old Dec 11, 2003 | 03:22 AM
KGAccord's Avatar
Default Re: Ignition + Plugs (D21X)
honda plugs are just repackaged NGK plugs.
iridiums are good in situations that it's difficult to change the plugs and you don't want to do it every 20k-25k. ie, on V6 Accords where those 3 three plugs are a bitch to get at.
Old Dec 11, 2003 | 05:14 AM
The_Todd's Avatar
Farts in the shower
Default Re: Ignition + Plugs (KGAccord)
If you arent running tons of power or an ignition system, oem is more than ok. I would say save your dough for other goodies
Old Dec 11, 2003 | 12:47 PM
ramoneguru's Avatar
Default Re: Ignition + Plugs (VRDrvr)
NGK....that's all should be about $5 and some change for 4 of em...
Old Dec 11, 2003 | 12:53 PM
iam7head's Avatar
Default Re: Ignition + Plugs (ramoneguru)
Ngk oem replacement..around 12 dollar out of door with tax.
get a omp meter and test the resistance in the wire before wasting money on a perfect set of sparkplug wire.(my number one cylinder wire is getting around .10 and the four cylinder around .15 vs .8 for all cylinder wire on my buddy's gsx elcipse with bling bling red aftermarket sparkplugwires.
stock wire also have a good RF interference resistance
check gap and torque the down properly
Old Dec 11, 2003 | 01:30 PM
fw190bvi's Avatar
Default Re: Ignition + Plugs (iam7head)
thanks.....im just gonna go to napa and get some basic NGK, whatever theyve got....and testing the wire first is a good idea....i was just planning on getting oem wires....the reason i want to replace them is they dont seal well....when i washed my engine bay, water got down into the sp housing......and the boots are starting to crack.....
Old Dec 11, 2003 | 01:36 PM
knowtomorrow3001's Avatar
You think if I took out my Nology silverstone plugs and switch to ngk plugs that may help my gas mileage. I just was told to get them for use with the Nology wires
but they may have just told me that to get my money.
Does anyone know anyone who uses these damn things
http://www.nology.com/hot.html
Old Dec 11, 2003 | 01:44 PM
97F22B2's Avatar
I use stock OEM plugs just 2 degrees colder and NGK blue wires on my boosted 97
Platnums and the like usually make the car run like **** or they dont last very long, but thats personal experience.
Old Dec 11, 2003 | 07:08 PM
The_Todd's Avatar
Farts in the shower
Default Re: Ignition + Plugs (knowtomorrow3001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knowtomorrow3001 &raquo;</TD></TR><TR><TD CLASS="quote">You think if I took out my Nology silverstone plugs and switch to ngk plugs that may help my gas mileage. I just was told to get them for use with the Nology wires
http://www.nology.com/hot.html</TD></TR></TABLE>
this is what they call a highjack on a thread, strictly gangsta
Michael Dee
Honda Insight & CR-Z Hybrid
Jan 18, 2014 06:11 PM
ZXiPoZ
May 3, 2012 09:25 AM
MintyDip
Jul 1, 2002 12:42 PM
Brandon
Jun 17, 2002 07:25 PM
