2000 Accord Code P1486
Old May 7, 2004 | 10:42 AM
SpoonEK2's Avatar
Default 2000 Accord Code P1486
Anyone else have this error code? The dealer wants $900 to change ECU's.
The tsb is 01-022. Anyone have it?
Old May 7, 2004 | 12:19 PM
Oh Crap's Avatar
Default Re: 2000 Accord Code P1486 (SpoonEK2)
Old May 7, 2004 | 12:48 PM
jfastman's Avatar
You have any other DTC's other that the P1486?
Old May 7, 2004 | 12:54 PM
jfastman's Avatar
You have any other DTC's other that the P1486? Is the coolant level low? Does the radiator fan run all the time with the ignition on? Check the radiator fan circuit, fan switch circuit and fan switch. Also, check the operation of the thermostat. If these all check ok, you will hafta replace the ECM.
Old May 8, 2004 | 12:19 AM
SpoonEK2's Avatar
Default Re: 2000 Accord Code P1486 (jfastman)
Thanks for responding...
I'm not sure if there are any other DTC's as this code was from the dealer's service diagnosis printout. They recommended replacing the ECM, but I will have to check on the cooling system. i don't have access to the car until my sister drives down so it will have to wait.
HST
Mar 8, 2018 02:27 AM
rkh3
Aug 30, 2009 05:27 PM
clair
Aug 12, 2009 09:24 AM
Project_ED8
24
Nov 22, 2003 12:16 AM
Nerv2g
Jun 30, 2003 04:15 AM
