troubleshooting codes
Old May 4, 2004 | 05:14 PM
accordboy99's Avatar
Default troubleshooting codes
hey im new and i have 99 accord lx sedan 2.3L sohc vtec and the check engine light is on and it is putting out a code P1705 can any body tell me what the code is nd why the check engine light is on
Old May 5, 2004 | 06:03 AM
JimBlake's Avatar
Default Re: troubleshooting codes (accordboy99)
My list says that's an automatic transmission code. No shift except 2-3, lock-up clutch not engaging.
Old May 5, 2004 | 07:05 AM
jfastman's Avatar
P1705; short in transmission range switch circuit. Do any of the gear indicator lights stay on when the trans is not selected to the indicated light? If no, you may have a problem in the wire harness from the range switch. If yes, disconnect the trans range switch. Do all the lights go out? Replace the range switch. Try this first, then post back here and I can walk you through the wire harness diagnosis later.
Tyler Cloutier
Sep 7, 2024 05:13 PM
blackj30_a
Mar 30, 2016 11:20 AM
chriscar00
Aug 25, 2013 05:46 AM
mann
Honda Civic (2001 - 2005)
Feb 8, 2012 06:58 AM
joshua89
Jul 30, 2011 01:36 PM
