second intake runner in plenum open....BAD?
Old Dec 5, 2004 | 04:23 PM
halfNhalf-83's Avatar
Default second intake runner in plenum open....BAD?
OK here is the problem...or concern i have with my engine! I had done this F22a swap (140hp) last year for my 93 lx 4dr. We have everything hooked up on the engine except this intake runner valve (circled in red)that hooks up from a air box and vacuum lines and a electronic solenoid. Apparently this is to open the second intake runner in the plenum for during high rpms, unfortunately it is open all the time because this isnt hooked up...is this causing me to run lean....i notice i dont have much low end power..could this be the problem? The thing is...i dont know how to wire the damn thing...i have the air box with the solenoid...which i got from the junkyard off a 95 accord ex.....i am not sure what wire goes where or how to hook up the wires..can someone please help...i think this is causing my car to run lean which is terrible on the engine....oh here is a quick snap of my car....not into big rims or anything...just like it clean...THNX guys
Old Dec 5, 2004 | 06:29 PM
Carolina Fried Rice's Avatar
Default Re: second intake runner in plenum open....BAD? (SMseagren83)
When I installed my intake I came accross the same problem. Searched and found that most people just cap off the vacume line and dont bother with the other stuff. I dont believe it would make you run lean but I may be wrong. Your pics arent coming up.
Bump, because I'd like to know if I'm doing the wrong thing also.
Old Dec 5, 2004 | 09:49 PM
Default Re: second intake runner in plenum open....BAD? (TSAF22B1)
is there a way to upload pics directly from my compter versus HTML?? anyways my understanding that it is bad to have all that allowed air to flow into the combustion chambers causing a lean burn at low rpms.( that is having both sets open) doesnt that make sense.....driviing my car around..lemme tell you i think we are both wrong..because i have sucky low end power...real sucky!! CAN SOMEONE TELL ME WHAT WIRES hook to what and WHERE TO HOOK UP,,AND HOW TO HOOK UP!!! PLEASE!!!
Old Dec 6, 2004 | 03:42 PM
come on guys...someone has to know!!!
Old Dec 6, 2004 | 04:18 PM
ZigenBallz's Avatar
Just take the vacuum hose from the black IAB box to the gold diaphragm and run it from the gold diaphragm to an unused nipple on the manifold and they will be controlled by vacuum...
but if you want to wire them up and have them be RPM acytivated by the ECU the you need to run the one wire from the IAB box to the PT6 ecu...and the other to a power source... if you don't have the corresponding ECU for the A6 motor then you are SOL and have to run it off of vac.
Old Dec 6, 2004 | 04:30 PM
Default Re: second intake runner in plenum open....BAD? (ZigenBallz)
how effeicient is that going to be running it off vaccum only..since i only have the A1 ecu?
Old Dec 7, 2004 | 08:54 AM
ZigenBallz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMseagren83 &raquo;</TD></TR><TR><TD CLASS="quote">how effeicient is that going to be running it off vaccum only..since i only have the A1 ecu? </TD></TR></TABLE>
Alot more efficient for low end tq than having the butterflies open all the time...
I run it off of vacuum... and they open at about 60-70% throttle or at 3500-ish rpm's... whichever comes first...
as opposed to running them off the A6 ECU and having them open at 4000-4400ish...
Both ways are fairly comparable to each other...
I have run it off the ECU also... and I liked it better running them off of vacuum so I switched back...
Old Dec 7, 2004 | 10:58 AM
OK so i will attempt to hook up the black air box with the vaccum lines....which ones go where? there are 4 vaccum lines? lol sorry but i searched for a diagram and couldnt find one!
Old Dec 7, 2004 | 11:59 AM
ZigenBallz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMseagren83 &raquo;</TD></TR><TR><TD CLASS="quote">OK so i will attempt to hook up the black air box with the vaccum lines....which ones go where? there are 4 vaccum lines? lol sorry but i searched for a diagram and couldnt find one!</TD></TR></TABLE>
No no no no...
You are bypassing the black IAB box...
Take the hose from the gold diaphragm on the manifold and hook it from that to the manifold... the black box is not involved at all...
R_Pizz3l
Sep 29, 2011 03:11 PM
djkurious
May 4, 2009 04:33 PM
johnnytwopoint
Apr 3, 2008 03:23 PM
halfNhalf-83
Dec 6, 2004 06:47 PM
1.6L_of_PURE_power
Jul 9, 2003 06:59 AM
