got a problem?
Old Dec 10, 2004 | 11:25 AM
91blksi's Avatar
Default got a problem?
when i started my car today, when i let go of the key it shut off, so i tried again and then it started right up but when i slipped it in drive(auto) it cut right back off. so i started it in neutral and no problems but when i try from park to drive it cuts off? whats the problem?
Old Dec 10, 2004 | 12:28 PM
95accordh22a's Avatar
Default Re: got a problem? (91blksi)
neutral saftey switch maybe... not sure
Old Dec 11, 2004 | 09:31 AM
91blksi's Avatar
Default Re: got a problem? (95accordh22a)
whats that?
Old Dec 11, 2004 | 10:23 AM
sincityEX's Avatar
its a switch that keeps you from starting the car in gear. the car can only be in neutral or park to engage the starter. so it wont crank in reverse or any drive gears.
Old Dec 11, 2004 | 11:53 AM
BudYsr's Avatar
Default Re: got a problem? (sincityEX)
I agree, definitely sounds like the neutral safety switch. Never fooled with one on a Honda, but it shouldn't be too big a deal.
Old Dec 13, 2004 | 07:29 AM
JimBlake's Avatar
Default Re: got a problem? (BudYsr)
Neutral safety switch won't make it stall. It's only for the starter itself.
Can you make it happen by wiggling the key? Or holding it partway between 'ON' & 'START'? If so, the electrical part of the ignition switch is flaky. Otherwise, look at main relay or else you'll have to do some wire-chasing with a DMM.
maddhatter1
Apr 25, 2021 12:09 PM
slq576
Nov 19, 2013 07:50 PM
badfish2282
May 15, 2009 08:45 PM
b00sted4dr
Jul 31, 2006 05:14 PM
91hob20hb
Jul 17, 2004 11:16 AM
