Old 03-25-2015, 10:55 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
installing cat-back exhaust on a 92
Old 12-09-2004, 06:37 PM
hndracng's Avatar
Default installing cat-back exhaust on a 92
i am trying to install my obx cat-back exhaust on my 92 accord but i can not break the bolts loose bc they are the original bolts and exhaust i was wondering is there anyway i can break them loose or would i have to cut them off and would that hurt anything on my catalytic converter
Old 12-09-2004, 06:43 PM
DCApex8's Avatar
Default Re: installing cat-back exhaust on a 92 (hndracng)
You used a breaker bar by chance? Some times a good tug with a long breaker bar is all it needs. If you have but still cant, a grinder to cut the bolt off might be needed.
Old 12-09-2004, 06:46 PM
hndracng's Avatar
Default Re: installing cat-back exhaust on a 92 (DCApex8)
oh ok so grinding the bolt would not hurt anything or cause exhaust leaks
Old 12-09-2004, 06:51 PM
FatJoe's Avatar
spray some jb-80 or wd-40 or PB blaster on those bolts, let em soak for a lil bit, and take an impact gun to those suckers
Old 12-09-2004, 06:55 PM
hndracng's Avatar
Default Re: installing cat-back exhaust on a 92 (FatJoe)
ok what if i dont have an impact gun and also what if the bolts are rounded out already from where someone previously screwed it up what would you recommend then
Old 12-09-2004, 07:34 PM
Farts in the shower
The_Todd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hndracng &raquo;</TD></TR><TR><TD CLASS="quote">ok what if i dont have an impact gun and also what if the bolts are rounded out already from where someone previously screwed it up what would you recommend then</TD></TR></TABLE>
Torch to heat the bolt and use vise grips to get them out or cut them...then replace with grade 8 bolts or take it to a exhaust shop to have them take out the tough bolts.
Old 12-10-2004, 05:34 AM
FatJoe's Avatar
Default Re: installing cat-back exhaust on a 92 (VR)
i would def torch em... i mean come on, we all know that EVERYONE loves to play with fire
escape2me
11-23-2005 08:06 AM
Honda_Accord
09-23-2005 08:38 PM
uranazo
26
01-14-2004 03:28 PM
MysticAzn03
02-19-2003 03:03 PM
GSRaCeRbOI
07-24-2002 10:07 AM
Quick Reply: installing cat-back exhaust on a 92
