Check engine lite
Old Apr 6, 2005 | 04:44 AM
casmello's Avatar
Default Check engine lite
When i start my car the check engine light blinks 4 or 5 times then turns off, does that mean anything
Old Apr 6, 2005 | 05:22 AM
JimBlake's Avatar
Default Re: Check engine lite (casmello)
Are you sure it's the check-engine light? The 'maintenance required' light blinks on startup when you're getting close in mileage, but I don't think the CEL is supposed to act like that.
Old Apr 6, 2005 | 05:33 AM
casmello's Avatar
yeah, sorry thats it 'maintenance required', does that mean i should bring it in for a checkup?
Old Apr 6, 2005 | 07:03 AM
JimBlake's Avatar
Default Re: (casmello)
That just counts miles since the last time it was reset. It probably tells you to get an oil change every 7500 miles, along with whatever else is scheduled at longer intervals.
Do your normal scheduled maintence according to the owner's manual or more often if you want. Here's how to reset the maintenance light on your 6th-gen:
1 - Key completely off.
2 - Press & hold trip-odometer reset button.
3 - Continue to hold the button as you turn the key 'ON' (don't need to actually start engine).
4 - Continue holding the button for maybe 20 more seconds. The light will eventually go out.
Old Apr 6, 2005 | 09:25 AM
briq4's Avatar
Default Re: (JimBlake)
10,000 miles it will come on and stay on with the newer Honda's.
Old Apr 7, 2005 | 04:02 AM
casmello's Avatar
Cool thanks alot for the info!
pens81
Acura TSX
Mar 30, 2006 03:42 AM
jizzer671
Nov 30, 2005 09:31 AM
francfurter
Dec 29, 2004 08:47 PM
Brian-Brian
Jun 6, 2003 01:49 AM
under_psi
Aug 16, 2001 12:50 PM
