tailight problems...
Old Apr 4, 2005 | 02:15 PM
JonnySBeee...'s Avatar
Default tailight problems...
after i took out the amber reflector off of my 96 accord, wen i put them back on the brake lights stopped working, any ideas of wut happened, wiring, bulbs itself? TIA
Old Apr 4, 2005 | 02:18 PM
CD7power's Avatar
Default Re: tailight problems... (jonny05)
maybe a loose harness? did u check if the bulb is all the way in?
Old Apr 4, 2005 | 04:24 PM
Default Re: tailight problems... (CD7power)
how would would a dealership charge me to diagnos the prob and fix?
Old Apr 4, 2005 | 04:30 PM
hondaracin24's Avatar
See if you can diagnosis the problem yourself so you can save yourself money and if your really stumped then bring it to the dealership.....
Old Apr 4, 2005 | 05:37 PM
YeuEmMaiMai's Avatar
This is easy to test. You can check the bulb with any 12V source and if it works, look at the wire harness, if it does not, replace it.
Old Apr 5, 2005 | 01:52 AM
Default Re: (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">This is easy to test. You can check the bulb with any 12V source and if it works, look at the wire harness, if it does not, replace it.</TD></TR></TABLE>
wut do i look at?? i looked at the bulb, they look fine but wut do i look for with the harness? burning or something...? please let me know anyone
Old Apr 5, 2005 | 01:47 PM
i just checked and my passanger side brake light wires came off completely but the dirvers side is intact....maybe wen one is out the other doesnt work?!? any info guys...
Old Apr 5, 2005 | 02:50 PM
Default Re: (jonny05)
you connect your lightbulb to directly to your battery and if it lights up you know the bulb is NOT the problem. I use leads with alagator clips on both ends and it works very well for testing lights
StreetRiot_DRE
Mar 4, 2008 07:16 PM
Fuster_Cluck
Audio / Security / Video
Oct 7, 2006 04:48 PM
roundworldsobig
Dec 16, 2005 08:53 PM
turbotime
Nov 12, 2004 10:15 PM
maxxdout
Dec 14, 2001 09:44 PM
