speedometer problem '91 EX
Old May 17, 2005 | 04:46 PM
poke708's Avatar
Default speedometer problem '91 EX
usually it happens when i drive 40mph sometimes the needle in the speedometer drops all the way down to 0mphs for a second or two. then it gets up to 40.
also sometimes it drops down to 20mph and then goes back up.
last time i even had problem with my Sporting light it started to blink after 15-20 seconds i stopped car and turned off engine then after few seconds I strated engine again and everything was fine
Old May 17, 2005 | 05:23 PM
deserthonda's Avatar
most likely is the electrical part of the speed sensor, i have seen many of them go bad but make sure all wiring and connections are good
Old May 17, 2005 | 07:26 PM
calgary_roclimber's Avatar
have a 90 accord, it did the same thing to me.
started off with intermittent problems...went away, came back after 2 months and after jumping for a bit, it went dead ( 0mph ).
replacing the speed-sensor resovled the problem.
i agree with deserthonda, check the wiring first, clean the contact and see if it makes any difference.
good luck.
psm321
Nov 27, 2018 03:13 PM
Blakemckee
Nov 18, 2006 08:27 PM
vedha
Nov 15, 2005 05:41 PM
bodiez
Aug 8, 2004 07:49 AM
64moon
Sep 20, 2003 07:29 PM
