Tec advise
Tec advise
I own 1990 Accrod LX. The fan on it blows hot air only. It does not change the temperature if I turn it down or up. What might be wrong with it? Thank you. Please help!!!!!!! It is too hot!!!!!!!
Modified by Myroslav at 7:54 AM 5/9/2005
Re: Tec advise (Myroslav)
On a 1990 accord I would say check to make sure that the **** isn't broken. If it is when you turn it nothing is happenign. If the **** is good either the hot water valve is stuck or the cable that opens and closes it is stuck.
Re: (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda »</TD></TR><TR><TD CLASS="quote">do you mean a/c not working???</TD></TR></TABLE>
It does not have A/C
I WOULD FOLLOW TURBOWA ADVICE.....IF THE **** IS OK,,,GET SOME VISE GRIP AND SQUUEzE THE INLET HOSE TO THE HEATER VALVE IF IT STARTS COOLING A BIT HEATER VALVE IS STUCK OPEN
Re: (Myroslav)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Myroslav »</TD></TR><TR><TD CLASS="quote">
It does not have A/C</TD></TR></TABLE>
Start with the **** then we'll go from there.
akaplan12
10-15-2007 09:09 AM
