solid, quality, cost efficient build on an H
Old Dec 20, 2005 | 12:32 PM
972drcordex's Avatar
Default solid, quality, cost efficient build on an H
ok so my block on the h is on its way out and Im due for a rebuild. I dont want to spend to much money but at the same time I dont want to use cheap materials. So I was thinking oem bearings, eagle rods, je piston heads etc. What would you guys use if you were rebuilding your block but didnt want to go crazy exspensive. So just list out what you would go with from who and where would you buy it from?
Old Dec 20, 2005 | 01:59 PM
i_kick_turtles's Avatar
Default Re: solid, quality, cost efficient build on an H (972drcordex)
Stick with the F
Are you going to turbocharge this motor?
If you get forged pistons, you'll need to resleeve. If you are on a budget the stock rods will be fine. I would go with Type S pistons, remove the balance shaft, and probably cam regrinds. Where to get those? well I have no idea.
Old Dec 20, 2005 | 02:04 PM
Default Re: solid, quality, cost efficient build on an H (I R Tylor)
could I keep stock sleeves with type s pistons?
Old Dec 20, 2005 | 07:16 PM
yes.
oldskoolracer
Jan 7, 2009 01:40 PM
young noob
Jun 15, 2007 03:53 AM
972drcordex
Dec 20, 2005 07:55 PM
HondaGuy02
12
Apr 17, 2004 09:47 PM
Howitt
Oct 1, 2002 05:27 AM
