electrical problem??
Old Dec 14, 2005 | 06:38 PM
f22pwrdaccord's Avatar
Default electrical problem??
Was driving home tonite and my headlights went out then the interior lights got super bright and the lights wont come on i replaced the reley and still isnt working everything else electircal works fine any ideas??
Old Dec 14, 2005 | 06:47 PM
P_Adams's Avatar
Default Re: electrical problem?? (f22pwrdaccord)
Designer Drug??
Check the appropriate Fuses. the headlamps are individually fused. I'm curious about the voltage spike (lights went super-bright)... No smell of sulfur from under the hood (overgharged battery) or other such occurances??
P
Old Dec 14, 2005 | 07:39 PM
Default Re: electrical problem?? (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">Designer Drug??
P</TD></TR></TABLE>
fuses are fine that was the first thing i checked no odd smells under the hood tho and no reason for the battery to overcharge i wouldnt think been driving around for a while with the new battery just all of asudden happend but everything in the car is workin like its supercharged with power minus the headlights not working??
Old Dec 14, 2005 | 08:01 PM
P_Adams's Avatar
It sounds like the alternator started overcharging (output voltage higher that 14.2 volts). A higher than normal voltage would make bulbs brighter and make motors run faster (wipers etc). Unfortunately, it has a tendence to blow out bulbs (which MAY be what happened to your headlamps) and drastically shorten electrical components life expectancy. Electronics have absolutely NO tolerance for excessive voltage, so get it checked quick!!
P
Old Dec 15, 2005 | 06:35 PM
problem fixed thanks for the helps adams changed out my alternator off my parts car and replaced the 4 blown bulbs and car runs fine now guess it was goin out and surging
Old Dec 15, 2005 | 06:41 PM
P_Adams's Avatar
Thanks for the "Fix" report and glad it worked out.
You're fortunate it didn't take out the battery. They have a tendency to either gas-out, overheat and blister the sides or just explode from the hydrogen gas igniting
P
Old Dec 15, 2005 | 07:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the "Fix" report and glad it worked out.
P</TD></TR></TABLE>
dont kno if this has anything to do with the battery but could it have helped that i have a dry cell battery?
Old Dec 15, 2005 | 08:15 PM
P_Adams's Avatar
I believe you're refering to the term "Maintainance Free" battery, often marketed as never needing water.
If you believe that, I've an Acme SkyHook that some guy was supposed to pick up 2day, but didn't show
If it is a true "M/Free" Battery, there will be no provisions for gaining access thru the battery top, No caps, no square covers (and no way to replace any water (Battery Acid) which may have boiled off from an Overcharge. Fortunately, thru the advantage of Modern Chemistry, they are more resistant to overheating.
Just keep an eye on it.
P
CaseyB
Nov 27, 2012 06:30 PM
traxxasx
Feb 8, 2009 08:17 PM
The Si
Aug 24, 2006 07:51 AM
halocivic
May 6, 2006 11:24 AM
steve_meyer
14
Sep 6, 2004 11:03 PM
