Fails emissions test
Old Jan 24, 2006 | 07:39 PM
unclewilco's Avatar
Default Fails emissions test
I have a '93 Accord with 190K mi and it hasn't passed the required minimum levels of nitrogen based oxides. I have added the fuel supplement from CRC to reduce emissions, added high octane fuel, and cleaned the EGR valve needle and port area, and inspected the EGR valve's diaphram for smooth operation. Although this did reduce the levels quite a bit, it still fails. Any ideas?
Old Jan 24, 2006 | 07:48 PM
YeuEmMaiMai's Avatar
Default Re: Fails emissions test (unclewilco)
high NOx emmissions are caused by EGR failure. I would start by cleaning the EGR ports on the intake. I'm betting that they are clogged.
Old Jan 24, 2006 | 09:46 PM
raceACCORDingly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unclewilco &raquo;</TD></TR><TR><TD CLASS="quote">I have added the fuel supplement from CRC to reduce emissions, added high octane fuel, and cleaned the EGR valve needle and port area, and inspected the EGR valve's diaphram for smooth operation. Although this did reduce the levels quite a bit, it still fails. Any ideas?</TD></TR></TABLE>
read much, hes already cleaned the egr
Old Jan 24, 2006 | 10:33 PM
Default Re: Fails emissions test (raceACCORDingly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly &raquo;</TD></TR><TR><TD CLASS="quote">
read much, hes already cleaned the egr</TD></TR></TABLE>
Cleaning the egr ports requires removing the fuel rail, drilling out the rivits on the cover, and cleaning passages on the underside of the cover and the holes in the Intake Manifold
So I have to ask you did you read what I said. Simply cleaning the port that the valve attaches to does jack...........
Here are the instructions
http://www.dhost.info/accordinfo/howto/egr.html
Old Jan 25, 2006 | 12:58 AM
Default Re: Fails emissions test (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">
im assuming he meant the valve and then the egr ports
Jeffrey9
Engine Management and Tuning
Sep 30, 2008 06:38 PM
emwavey
10
May 27, 2004 06:34 AM
Audipwr1
Mar 5, 2004 08:42 AM
