help with engine and maintenance
Old Jan 30, 2006 | 01:20 PM
osuperjohno's Avatar
Default help with engine and maintenance
I drive a 02 accord coupe auto and whenever I have to wait those long lines for the left turns, I leave my tranny on neutral and wait for the green light to put it back to drive...is it okay to switch to neutral whenever i'm on a red light like I would for a stick? is that good for auto or bad?
also, how often do i have to change the spark plugs? i'm at 68k
Old Jan 30, 2006 | 02:22 PM
wingback44's Avatar
Default Re: help with engine and maintenance (osuperjohno)
i think it is fine to go from neutral to drive so long as you arent neutral dropping it.
Old Jan 30, 2006 | 04:02 PM
Ross 2.0's Avatar
In a Junkyard near you.
I do that when the car is still warming up so it can warm up a little quicker. But as far as doing that at stoplights after it's warmed up it makes no difference, no help or hurt.
You only need to change your NGK platinum plugs at 105K miles.
Old Jan 30, 2006 | 05:01 PM
YeuEmMaiMai's Avatar
leaving the car in gear does not hurt either.........
Old Jan 31, 2006 | 12:13 AM
i put it on neutral because i believe it saves gas compared to putting it on drive on the long left-turn stoplights...is that right?
Old Jan 31, 2006 | 01:04 AM
doesn't make a difference in terms of fuel economy.....
JackieMoon1989
Apr 9, 2012 09:40 AM
osofastferu
Jul 18, 2010 10:28 PM
B_1_8_hatch
Nov 9, 2003 04:58 PM
r4m3n
Apr 30, 2002 06:59 AM
strils
Dec 28, 2001 07:52 AM
