Ecu problem.
Old Oct 30, 2006 | 03:27 PM
Guru Designs's Avatar
* B A N N E D *
Default Ecu problem.
I just finished my h22 swap into a 94 honda accord ex. now for some reason the ecu isnt grounded. where are the ground points to the ecu. all the engine grounds are placed and tight. SO my question is where are the ecu grounds located at. it has 12v but no ground. thanks for your help in advance.
Old Oct 30, 2006 | 03:33 PM
TheMuffinMan's Avatar
He knows where you live!
You could just ground it anywhere could you not?
Old Oct 30, 2006 | 03:36 PM
* B A N N E D *
yes thats what i did to get the motor tarted but i would like to know where are the stock ground location for the ecu so that i could check and see what the deal is.
Is it in the main relay? thanks in advance.
Old Oct 31, 2006 | 09:06 AM
* B A N N E D *
any one?
Old Oct 31, 2006 | 12:35 PM
* B A N N E D *
just for future refrence. the ECU ground point is at the intake manifold next to the master cylinder on the vacuum block.
Old Oct 31, 2006 | 12:38 PM
kulrevon's Avatar
Default Re: (Guru Designs)
are you sure the ecu ground isn't the one on the thermostat housing?
Old Oct 31, 2006 | 02:47 PM
* B A N N E D *
Default Re: (kulrevon)
hmtcrxsir
Aug 8, 2007 01:22 PM
Legion
Jul 9, 2007 11:27 AM
93cavRS
Oct 10, 2006 12:25 PM
Frcfedintegra
Apr 29, 2003 05:10 PM
mockujin
Nov 17, 2002 06:06 AM
