3rd gear problem...
Old Oct 25, 2006 | 10:33 AM
jli18's Avatar
Default 3rd gear problem...
i was drivin with a friend yesterday and while i was in 3rd gear, i accidently shifted to neutural without applying the clutch pedal. is this a sign that the clutch needs to be replaced?
Old Oct 25, 2006 | 07:50 PM
JimBlake's Avatar
Default Re: 3rd gear problem... (jli18)
Not necessarily. Worn clutch will slip when you give it lots of gas.
If you're just balanced between accelerating & engine-braking, you can shift your tranny out of any gear. That's normal.
Old Oct 25, 2006 | 09:47 PM
jli18's Avatar
Default Re: 3rd gear problem... (JimBlake)
really? thats good to hear. thx man
Old Nov 4, 2006 | 06:37 PM
tekstyle's Avatar
the moment u release the gas pedal, u can pop it out to neutral. that is normal. u can do that on any gear. however, if u want to shift without clutch, u need to rev match really well. some cars can do it easily like on my friend's rx7, but not sure about integras, at least not mine, nor would i want to do that.
Old Nov 5, 2006 | 08:42 PM
jli18's Avatar
Default Re: 3rd gear problem... (tekstyle)
yeah i have heard that u can shift without applyin clutch pedal. but u need to do somethin to the pedal? i dont know
Old Nov 5, 2006 | 09:07 PM
ayougo's Avatar
its called powershifting and it has nothing to do with the clutch pedal.
All you realy do is shift so fast you dont give the engine time to drop rpm's and your able to do this by simply applying throttle till desired point, and shifting W/O the use of the clutch while the rev is climbing EXTREMELY fast. Search you tube for "powershift"
Old Nov 5, 2006 | 09:12 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jli18 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i have heard that u can shift without applyin clutch pedal. but u need to do somethin to the pedal? i dont know</TD></TR></TABLE>
ask the any manual car owner that use autobrake club on their club pedal
little did they know you can drive the car without stepping on the clutch
Edwaad Truon
Jan 15, 2013 10:24 AM
ablack934doorcivic
Nov 1, 2005 02:02 PM
Chief Brody
Aug 4, 2004 09:28 PM
MrBite
Dec 11, 2001 04:34 AM
tc
Jul 31, 2001 10:10 AM
