idle/jerking problem multiple CELs
Old Oct 20, 2006 | 06:57 PM
ph0on's Avatar
Default idle/jerking problem multiple CELs
Hey guys, I'm having a problem with my 95 LX. I just swapped in a JDM F22B dohc and the thing's having some major runability problems. My mechanic wasn't sure how to check the CELs without the new engine's vin for some reason, so they gave me my car back to get them myself.
The car has a real tough time starting up if the engine's cold, it takes a few attempts to get the engine to keep running. The first few times it either doesn't start or the idle gradually slows until it dies. If I try to give it gas when it does this the throttle takes at least a second to respond and the engine pops loudly and dies. After that it will start up and have an irregular idle, and when a certain rpm range is hit (in all gears as well as neutral), the rpm will bounce up and down and make the car jerk if being driven. It happens just as the gas is slightly depressed, cruising at a low rpm until the late 2000s.
I checked which CELs it would throw at me & got codes 1, 14 and 6.
1 - O2A - Oxygen sensor #1
14 - IAC (EACV) - idle air control valve
6 - ECT - water temperature sensor
I found a few threads about people getting the same problems & changing their IACs only to have the problem persist. If anyone has any ideas / input I'd really appreciate it.
I'll put up links to the other threads I found so you can read a little bit more of what other people went through..
https://honda-tech.com/zerothread?id=702070
https://honda-tech.com/zero...age=2
Old Oct 20, 2006 | 08:48 PM
hondadude's Avatar
Default Re: idle/jerking problem multiple CELs (ph0on)
Ground at the T-stat housing
Old Oct 20, 2006 | 09:07 PM
ph0on's Avatar
Default Re: idle/jerking problem multiple CELs (hondadude)
could you be a bit more specific? as in, what exactly do you mean & what would this take care of?
thanks
Shidou
Apr 10, 2017 01:08 PM
4tika4
Apr 19, 2009 09:43 AM
2000civicsi
10
Oct 26, 2005 04:05 PM
T-Mo
11
Sep 28, 2003 10:17 AM
stRtypR25
Jan 12, 2003 03:09 PM
