Help please - Help
Old Oct 29, 2006 | 02:28 AM
jojo69's Avatar
Default Help please - Help
93, accord EX, auto, 161k
after getting some gas last night, got in my car and it would not start. It happend once before and then it starts later on.
After i got it towed last night, it started.
I just replaced, O2 sensor, Igniton module control.
Any idea how to troubleshoot it?
Or what could be causing this?
Thank you all
Joey
Old Oct 29, 2006 | 03:18 AM
Duane_in_Japan's Avatar
Default Re: Help please - Help (jojo69)
You need help to troubleshoot next time it wont start, you will need to check for fuel pressure by cracking the 12mm nut on top of the fuel filter and see if fuel constantly runs out while cranking, you will need a spare spark plug to put in a sparkplug wire that you will pull from one of the cylinders, insert spare plug into wire and ground end of plug to engine, crank engine and see if you have spark.
I am betting on a bad fuel pump or main relay, towing it shakes the pump out of its dead spot. You can give a couple of really hard hits on the gas tank while cranking and see if the pump comes alive. A tech with a scope can see a bad pump so if you have to get it towed, go to a shop with a scope.
Old Oct 29, 2006 | 04:05 AM
jojo69's Avatar
Default Re: Help please - Help (Duane_in_Japan)
Duane,
Thank you so much for your help.
I forgot to mention that it cranks but it does not start. I am not sure if that makes a difference.
Thank you again
Joey
Old Oct 29, 2006 | 04:09 AM
jojo69's Avatar
How can i check my relay?
Which one?
thanks,
Joey
Old Oct 29, 2006 | 10:24 PM
MAIN RELAY is all over the archives, please do a search, but dont waste your time, check for fuel pressure and that will tell you if the main relay is working or not. See my name and the item by my name, that is a main relay, up under the dash on the drivers side.
Old Oct 31, 2006 | 02:16 PM
jojo69's Avatar
Thank you again for your help.
I just confirmed that the Main relay itself is not the problem.
Can you tell me how to check fuel pressure?
I did some search but still not that clear.
Car now is not running at all. It cranks but it does not start.
It starts when it wants to.
Thank you all guys
Joey
Old Nov 1, 2006 | 05:04 AM
Loosen the 12mm nut on top of the fuel filter, gas may leak out initially, Turn the key so the idiot lights come on and the CEL also comes on, the fuel pump should come on as long as the CEL is on, 2 - 3 seconds and fuel should be running out of the filter. If no luck then try to crank the engine and if you still have no fuel squirting out then you have a bad main relay, fuel pump, blown fuse, broken fuel pump wire or bigger problems. An assistant would be nice.
Old Nov 1, 2006 | 04:38 PM
grandbud's Avatar
have you tried to hold the key all the way forward and hold it forward to see if car starts mine was acting like that and was the ing. switch not the pump or relay most of the time a fuel pump either works or it doesnt have one person kneel down at the back of car the other turn key on if you here the pump then the pump is good I hopes this helps this site has helped me alot ttyl
matmcg
Nov 21, 2010 01:39 PM
ja20_eg
Sep 29, 2009 02:53 PM
david542
20
Jul 20, 2007 03:31 PM
flyguy0086
Jan 23, 2007 10:11 PM
econobox
Oct 21, 2004 05:25 PM
