code 92
Old Feb 28, 2007 | 02:44 PM
hecubus's Avatar
Default code 92
96 accord LX 2.2 178k
could a "code 92" be caused by a bad fuel vapor canister? If so is there an easy way to test the canister?
Old Feb 28, 2007 | 02:58 PM
hondadude's Avatar
Default Re: code 92 (hecubus)
maybe you have a code 9 and also a code 2?
Did you get the codes by the OBD2 connector behind the ashtray?
Was a scan tool used?
Here's a link to help you;
http://members.troublecodes.ne...s.txt
Old Feb 28, 2007 | 03:11 PM
hecubus's Avatar
Default Re: code 92 (hondadude)
i use the "short out the connector thing under the glove box & read the flashes" bit & it blinked out 9 long flashes followed by 2 short ones less than a second after the last long flash then repeated the sequence...
only thing I've done to test is hook up a vacuum gauge to that hose that comes out of the bottom of the canister & rev the engine to 3500rpm & held it for ~1 minute with the gas cap off.
results were a slight blip in vacuum to maybe 3" then it dropped back down to zero & stayed there while the engine was turning at 3500rpm
Tyrell Bivens
Jul 31, 2015 02:46 PM
[713]
Oct 21, 2008 12:13 PM
96tegsr
Aug 22, 2003 08:37 AM
speedymon
Jul 16, 2002 08:39 PM
