91 Accord 5pd F22A1 engine+trans into 87 LXI 5 spd ?
Here's what I have:
-87 Accord LXI with a bad transmission
-91 Accord with an F22A1 and damaged body. both cars are 5 speed
Is it possible (and would it be worth it) to swap the F22A1 drivetrain into the 87?
these are the engine specs, from http://www.integra.orcon.net.nz/engines
A20A3 2.0 12V SOHC PGM-FI
110hp@5500rpm 114tq@4500rpm
87 Accord LX-i
F22A1 2.2 SOHC PGM-FI
125hp@5200rpm 137tq@4000rpm
90-93 Accord
87 Accord LX-i
90-93 Accord
Re: 91 Accord 5pd F22A1 engine+trans into 87 LXI 5 spd ? (philadd)
Hi... just need your advise.
I am having Accord 91 Manual and now swapped with JDM H22A LSD manual tranny. The problem is, the <U>offset of dryshaft </U>to its wheels is huge. What is the replacement model (or code) for the tranny (LSD if possible) so that to solve the offstted.
Thanks
Thanks
Re: 91 Accord 5pd F22A1 engine+trans into 87 LXI 5 spd ? (tronic)
I am having Accord 91 Manual and now swapped with JDM H22A LSD manual tranny. The problem is, the offset of dryshaft to its wheels is huge. What is the replacement model (or code) for the tranny (LSD if possible) so that to solve the offstted.
Thanks
Thanks
bonbon
03-13-2005 09:53 PM
